Having problems with controlling a Radia 6 channel dimmer
I can't get control of this light dimmer with a touch panel
Unit is wired Axlink and Prolink, Prolink button panels work fine, I see the units in the online tree but don't have any preset functions
Any ideas?
brian
Here's the code I have
(* LIGHT CONTROLS *)
BUTTON_EVENT[PANEL_A,401] // LIGHTING PRESET 1
BUTTON_EVENT[PANEL_A,402] // LIGHTING PRESET 2
BUTTON_EVENT[PANEL_A,403] // LIGHTING PRESET 3
BUTTON_EVENT[PANEL_A,404] // LIGHTING PRESET 4
SEND_COMMAND LIGHTS_A,"'RP',ITOA(BUTTON.INPUT.CHANNEL-400)"
IF(ROOMS_COMBINE)
SEND_COMMAND LIGHTS_B,"'RP',ITOA(BUTTON.INPUT.CHANNEL-400)"
BUTTON_EVENT[PANEL_B,401] // LIGHTING PRESET 1
BUTTON_EVENT[PANEL_B,402] // LIGHTING PRESET 2
BUTTON_EVENT[PANEL_B,403] // LIGHTING PRESET 3
BUTTON_EVENT[PANEL_B,404] // LIGHTING PRESET 4
IF(ROOMS_COMBINE)
  • FrankieFrankie Posts: 71
    Try Send_String.... I think, off the top of my head, that the Radia uses Send_Strings..
  • yuriyuri Posts: 861
    if its the real device, use send_string :p
    Yes, Radia dimmers use SEND_STRING.
    Supposedly they also have levels, but no one knows for sure whether they work or not.
  • KouyaKouya Posts: 60
    Thanks to all that replied. I tried the send string command...and it didn't work.
    Upon closer study of this code I figured...maybe if I rewrite the button_events statement for each preset by labeling them 'Rp1' , 'Rp2' .....etc
    So as a test I left the code intact and changed 'Rp' to 'Rp1' reloaded it and now all four presets are working.
    Go figure.
    Again thanks for your input
    brian
