Anyone found a good water proof RF remote?
in AMX Hardware
Hello all,
I'm planning on putting a water proof RF remote in a pool and/or Hot Tub to give the user some basic controls (Volume up/down, mute, system off)
I'm looking for something that will output RS-232 commands that I can grab and use.
Any ideas?
thanks in advance.
ejm
Any ideas?
thanks in advance.
ejm
http://www.rticorp.com/products/u1.shtml
Thanx!
From what I see we'd need:
U1 Waterproof controller
CM-232 Serial Communication Module
RP-6 Remote Control Processor
Theatre Touch Designer Software
This would essentiall enable me to take a button push from the U1 remote and have the RP-6 output some kind of hex string of my choosing to an RS-232 port on AMX and then do thus and so...
OR
can this remote speak directly to an AMX wireless reciever?
is so?
If so..
thanks so...
much
The RTI T2+ and RTI T1 remotes (with approriate firmware and AMXRF codes from RTI),
Can communicate directly to an AMX AXR-RF (433Mhz).
I don't see why the U1 wouldn't be able to do the same.
Anyway - hopefully all this helps and let us know what you wind up doing.
So the equipment you'd need would be:
U1 remote
AXR-RF 433, and an axlink connection between it and your master controller.
One more note getting the U1 programmed. You must call or e-mail RTI tech support to get the "special" codes, as well as a bug fix for their TheaterTouch editing software.
