Pcs2
in AMX Hardware
Could somebody explain how the outputs of the PCS2 behave when sensing a device conected to it?
Define_Device dv_IO = 5001:17:0 // I/0 = PORT 9 DATA_EVENT [dvCD] ///send stop to cd player { online: { pulse [dvCD,2] SEND_COMMAND dvCD,'SET MODE IR' // sets IR port 9 to IR mode SEND_COMMAND dvCD,'SET IO LINK 1' // sets IR port to link with I/O channel 1 (port 17) send_command dvCD, 'CARON' } } DATA_EVENT [dv_IO] /// I/O sensor input port 17 of NI4000 ch 1 & 2 { online: { send_command dv_IO,'SET INPUT 1 LOW' send_command dv_IO,'SET INPUT 2 LOW' send_command dv_IO,'SET INPUT 3 LOW' send_command dv_IO,'SET INPUT 4 LOW' } } CHANNEL_EVENT[dv_IO,1] /// IO current sensor for play/ffwd-rewnd on cd { ON: { wait 3 { if ([dv_IO,1]) nCDIO_PLAY = 1 } } OFF: { wait 3 { if (![dv_IO,1]) nCDIO_PLAY = 0 } } } CHANNEL_EVENT[dv_IO,2] /// IO current sensor for stop/pause on cd { ON: { wait 3 { if ([dv_IO,2]) nCDIO_STBY = 1 } } OFF: { wait 3 { if (![dv_IO,2]) nCDIO_STBY = 0 } } }
