Plasma or LCD with IP control
Does any one know of any LCD's or Plasma's that have IP control????
  • no, not exactly.
    but you may consider installing a serial to ip redirector for the display point.
    search for something like 'LS100 Ethernet to Serial Converter Box' as an example.
    of course, you could also install an NI-700/900 if you have some remote displays clustered together.
    i would like to hear if such a display is around, but i would expect it would limit your field of options.
  • sony lcd with network
    okay, i've now come across SONY LCD displays, that have an IP module as an option.
    i have this quote from Sony,
    ___________________________________________________________
    The BKMFW32 is an IP addressable Network Management Adaptor for Sony Public Display FWD Series with the common interface of the FWD Option Slot. It enables the FWD Series to be controlled, monitored and accessed from a Windows computer connected to LAN, WAN or the Internet.
    from http://www.sony.com.au/business/catalog/product.jsp?categoryId=34353
