XM Tuner module
Does anyone know of an AMX module for any manufacturer's XM Tuner? I know there is one for the Antex Sirius receiver, but I see nothing the Antex's XM receiver nor do I see a module for any XM receiver.
This doesnt seem right especially since C******* has there own XM tuner plus modules for other manufacturer's XM tuners. Time to catch up guys!!
    wcravenelwcravenel Posts: 114
    http://www.amxforums.com/showthread.php?t=862&highlight=Polk
    The above thread will get you going with a Polk RT12.
    Bill
    More XM
    Search InConcert for ADA. ADA (Audio Design Associates) makes a product called TuneSuite. There should be a NetLinx module for TuneSuite.
    banobano Posts: 173
    This module will work for the Antex XM receiver. The only change is the baud rate......which amx tech support kindly adjusted.
    Good Luck!
    ondrovicondrovic Posts: 217
    is this the same one that can be downloaded in InConcer?
    banobano Posts: 173
    I believe so, however this module was sent to me prior to being offered from InConcert.
    Polk XRT12
    I have a module converted from Cre$tron, that works on the Polk XRT12. Its a little messy, but gets the job done and is RS-232. Reply and I will post it up.
    I would like to take a look at it if you dont mind
