Nxc-vol4
lattanzi
Hi guys
I'm working with a VOL4 device and experiencing a strange behaviour.
I've used 4 bars to control the volume levels as you can see from the image attached.
Sometimes the bars stop showing the current volume and start to behave like a vu-meter: level values go up and down without any evident reason!
Here is some code
Any hint?
Here is some code
vVOLUME = 33003:1:0 MIXER_CH1 = 32001:1:1 MIXER_CH2 = 32001:2:1
// used to store volume levels when power goes down PERSISTENT INTEGER MIXER_VOLUMES[4] // used to store current volume levels INTEGER MIXER_VAL[4] DEFINE_CONNECT_LEVEL (vVOLUME,1,vTP2,2,MIXER_CH1,1) (vVOLUME,2,vTP2,3,MIXER_CH1,2) (vVOLUME,3,vTP2,4,MIXER_CH2,1) (vVOLUME,4,vTP2,5,MIXER_CH2,2)
DEFINE_START CREATE_LEVEL MIXER_CH1,1,MIXER_VAL[1] CREATE_LEVEL MIXER_CH1,2,MIXER_VAL[2] CREATE_LEVEL MIXER_CH2,1,MIXER_VAL[3] CREATE_LEVEL MIXER_CH2,2,MIXER_VAL[4] SEND_LEVEL vVOLUME,0,MIXER_VOLUMES[1] SEND_LEVEL vVOLUME,1,MIXER_VOLUMES[2] SEND_LEVEL vVOLUME,2,MIXER_VOLUMES[3] SEND_LEVEL vVOLUME,3,MIXER_VOLUMES[4]
// volume + BUTTON_EVENT[vTP2,180] BUTTON_EVENT[vTP2,181] BUTTON_EVENT[vTP2,182] BUTTON_EVENT[vTP2,183] { PUSH: { LOCAL_VAR INTEGER SELECTED_CH // [1..4] SELECTED_CH = (BUTTON.INPUT.CHANNEL%180)+1 IF(MIXER_VAL[SELECTED_CH] < 255) { SEND_LEVEL vVOLUME,SELECTED_CH,MIXER_VAL[SELECTED_CH]+1 MIXER_VOLUMES[SELECTED_CH] = MIXER_VAL[SELECTED_CH] } [vTP2,188+SELECTED_CH-1] = FALSE // mute off } } // VOLUME- BUTTON_EVENT[vTP2,184] BUTTON_EVENT[vTP2,185] BUTTON_EVENT[vTP2,186] BUTTON_EVENT[vTP2,187] { PUSH: { LOCAL_VAR INTEGER SELECTED_CH // [1..4] SELECTED_CH = (BUTTON.INPUT.CHANNEL%184)+1 IF(MIXER_VAL[SELECTED_CH] > 0) { SEND_LEVEL vVOLUME,SELECTED_CH,MIXER_VAL[SELECTED_CH]-1 MIXER_VOLUMES[SELECTED_CH] = MIXER_VAL[SELECTED_CH] } IF(MIXER_VAL[SELECTED_CH] > 0) [vTP2,188+SELECTED_CH-1] = FALSE // mute off } } // MUTE on BUTTON_EVENT[vTP2,188] BUTTON_EVENT[vTP2,189] BUTTON_EVENT[vTP2,190] BUTTON_EVENT[vTP2,191] { PUSH: { LOCAL_VAR INTEGER SELECTED_CH // [1..4] SELECTED_CH = (BUTTON.INPUT.CHANNEL%188)+1 SEND_LEVEL vVOLUME,SELECTED_CH,0 MIXER_VOLUMES[SELECTED_CH] = 0 [vTP2,187+SELECTED_CH] = TRUE } } // LEVEL_EVENT PER MIXER VOLUME LEVEL_EVENT[vTP2,2] LEVEL_EVENT[vTP2,3] LEVEL_EVENT[vTP2,4] LEVEL_EVENT[vTP2,5] { SEND_LEVEL vVOLUME,LEVEL.INPUT.LEVEL-1,LEVEL.VALUE //SEND_STRING 0:1:0,"'LEVEL.INPUT.LEVEL=',ITOA(LEVEL.INPUT.LEVEL)" //SEND_STRING 0:1:0,"'LEVEL.VALUE=',ITOA(LEVEL.VALUE)" MIXER_VOLUMES[LEVEL.INPUT.LEVEL-1] = LEVEL.VALUE IF(LEVEL.VALUE > 0) [vTP2,188+LEVEL.INPUT.LEVEL-2] = FALSE ELSE [vTP2,188+LEVEL.INPUT.LEVEL-2] = TRUE }
Any hint?
Have i been clear enough?
I have never experienced it with an AMX Vol Controller.
My problem was the the processor was parsing the data from the XAP and was getting stuck in a kind of loop. The only way to fix it was to go to a "fake feedback" setup and then just update the XAP blindly. It doesn't help that when a panel goes offline any combined levels go to zero. It would help if they would just stay where they are currently at and then update once the panel comes back online, I feel this is an AMX design flaw in G4 panels.
you are sending the level to level 0,1,2,3
and in your code above that you are using levels 1,2,3,4
that seems incorrect to me
also,
in your button events below that, I think you should use
(BUTTON.INPUT.CHANNEL-179) and remove the +1, instead of
its less for the processor to do and its more definitive, IMO
You were right in your first post: in define_start i use 0,1,2,3 while in my button_event i use 1,2,3,4
I also think that here:
this line is superflous:
the level is automatically updated...isn't it?
Thanks for your patience
