IP camera with 7 frames per second
joec
Hello, we are having a really hard time finding an IP camera that will provide around 7 frames per second to the 5" and 7" modero panels.
We tried the Bosch cameras and we were only able to get 1 FPS which is not accpetable.
AMX says that they don't know of any IP cameras that will provide better than 1 FPS
So my question is, does anyone know of any IP cameras that will provide approx 7 Frames per second to these panels?
Have you looked into Channel Vision's cameras? I've used them once, and on an internal network they would get up to 30fps, but only could get 1fps on an 8400 - the limitation of the panel. Anyway, viewing from a remote location, it would drop down to around 10-12fps.
Hope this help.
If we can get 10fps on the local ip cameras, we would be very happy...
Do a google search for AXIS.
For indoor use the AXIS 260 mjpeg cam has excellant PQ and is just over $300.00 no PTZ.
THANKS
Are you able to get 7+ fps to the 5"-7" touch panel with these cameras?
