Serial Parsing and Queing in DEFINE_PROGRAM
Greetings,
Since Netlinx it has been convetion to keep DEFINE_PROGRAM reserved for feedback. However, I've been able to write more efficent parsing and queing routines for serial communications by placing them in the DEFINE_PROGRAM section.
Is anyone else parsing or queing this way? Just curious.
Thanks!
Thanks!
My parsing commands are only executed if the buffer has a length greater than 0.
I use the DATA_EVENT for a CANCEL_WAIT / WAIT arrangement for an incomplete or corrupted message to timeout and dump the buffer.
This works especially well with UPB!
Even if your device sends one character at a time, one second apart just let it sit in the buffer until you get what you want. Just because you get data into a buffer doesn't mean you have to use it right away.
The mainline is checking your IF statement around 1000 times a second, compared to the below code which will only check when there is an incoming STRING.
The buffer will keep loading until it see's a CR and then trigger the PARSE_DATA(). Also, when using a BUFFER for large strings, create it using the CREAT_BUFFER in the DEFINE_START. I've done test where I loaded around [20000] in a VARIABLE (BUFFER) and it wouldn't get all the data sent, but when I used the CREAT_BUFFER it did receive all the data. I was told it is design to receive larger amounts of incoming data faster, because it ranks above a normal variable in the structure of the compliled program.
So even if a string is incomplete the "WHILE" tests for the condition which in this case is FIND_STRING(Buffer,"'CR'",1) if there isn't one it exits. If there are "CR"s you get everything up to and including the first one (if that's what you want to do) and the "WHILE" loops goes around again and you get the next "CR". When the buffer no longer has a "CR" which is often the case when you get incomplete string the "WHILE" exits leaving the incomplete data in the buffer and you exit your DATA_EVENT. The remaining string comes in and initiates another DATA_EVENT and the "WHILE" repeats what it did before picking up where it left off. The new data is appended to the existing (remaining) data left in the buffer. That is of course if your buffer is large enough to handle the left over data and the new (delayed) data.
Your confusing a "WHILE" with a "WAIT_UNTIL".
I thought convention was to put feedback in a TIMELINE_EVENT...?
No - as already mentioned, I believe the most efficient is the DATA_EVENT -> STRING: -> WHILE(FIND()) method...
TN 616 has an example of what a string handler might look like in the wild. In the example there, the buffer size is 100 which may not be large enough. Particularly for Clear1 stuff (which, it appears, the example writer may have had in mind) . My experience is that a couple of XAP 800s can spew out vast quantities of bytes, particularly when recalling presets.
In AXcess:
- the WHILE end automatically after 0.5 secs.
- the MEDIUM_WHILE doesn't end and doesn't track message buffers (PUSH/RELEASE, etc) for changes (!)
- the LONG_WHILE desn't end but checks message buffer for changes
In NetLinx:
any of the WHILE types doesn't end automatically!!! :eek: So it's "easy" to program and endless loop, and in most cases, you then need the magic "Runmode Disable" switch.
So what I mostly do is to program a counter into the WHILE and if the limit is reached, I manually set the WHILE condition to false.
The following is just a part of a code: So if the check to "$0D,$0A" takes too long in any way, I reset the Buffer so the WHILE fails.
There are lots of ways to ensure you don't get into an endless loop but with a While (find_string(buffer,......,1) followed by a remove_string or get_buffer_string etc you usually don't get into trouble.
Often, that is all that I have in DEFINE_PROGRAM ... a few tests to see if my buffer needs processing, and fire the routines to do that if needed. I have found it to be more reliable and faster than using a STRING handler for serial devices. Perhaps I just haven't done my STRING handlers properly, but it seems to me sometimes I don't get a trigger when there is valid data in the buffer.
If you're only checking a couple devices in a single system, I know it's not a problem, but if you're talkng about a system that has many sub masters communicating back to a main master, you have to be aware of the processing power.
My weather module uses - IF(FIND_STRING(sBuffer,"'/HTML'",1)) to start the parsing and the buffer can receive up to [25000] before it triggers the parse function. Devices that need commands timed before sending - Lighting, Security, Thermostats, etc. I use the TIMELINE set to the proper time for each device.
Yes, you need to use CREATE_BUFFER for large incoming strings; however, it has nothing to do with the speed of the data coming in. The data can drip in 1 byte a second and it still won?t work without CREATE_BUFFER. It has to do with a string concatenation limitation. Even though we can work with 64K chunks of data, for some reason we can?t concatenate anything over 15999 bytes. Yet CREATE_BUFFER can. I don?t know why the limitation exists but here is code to prove it does: Here is the output when button 1 is pushed:
Line 1 :: Length of cBuffer = 15999 - 01:06:27
Historically speaking, I have always parsed incoming data within the data_event string: handler. That is, until I needed to parse a massive amount of data coming back from several XAP800's. As I was watching the data come in, I would see the string: handler activate, but for some reason, much of my feedback and variables were not set properly. I moved the entire section into an if statement running in mainline and everything worked much more smoothly. If I have lots of data to parse, I'll usually pass it off to a function from the if statement. The only thing I do inside the string: handler at this point is append data.text to the existing rx_queue.
When sending strings, I generally queue them up and add a delimiter to the end of the tx data. I then pass this to a system call running in mainline which send the strings. The system call accepts the queue, the device to send to, and a delay to wait between transmissions. Not to different that running transmission from a timeline.
Of course, very few of my projects involve any master to master communication, so doing things this way seems to work well without any noticable downside.
As the previous poster stated, I use a $0D as a delimiter in my outgoing queue and REMOVE_STRING looking for the $0D, until the queue is empty. The only WAIT that I will use is one that starts every time something is found in the buffer and canceled when it is sent. I use it in case I get junk in the buffer for some reason to allow it to timeout and be cleared.
I personally never do parse serial information in define program. I find it very old fashioned.
Also on very large systems which I deal with often, this would be horrible. Your processor would be so slow it would be ridicolous. I have seen it happen.
If you run a counter in mainline you can track how different it is. Why not just parse everything in the string event for the device. It is much cleaner.
Also for that matter, on very large systems I use multiple staggered timelines for feedback instead of putting feedback in define program. When you have hundreds to thousands of buttons, having them in define program is nuts.
But even when I do small systems, i always use timelines it is just more efficient. For example use a timeline that only checks feedback every 10th or half a second. This is plenty fast for feedback.
If you check processor usage. YOu can see the difference.
It just seems better to always do it that way.
It will work doing in define_program. But why? It is using old access convention.
Oh and just make a very efficient small function for sending out strings, so it is only accessed when you call the function.
Have trigger fire then call function.
Why would you want to check the state of a projector every 0.1 seconds?
As far as putting waits in the String event for data over 64 bytes or incomplete messages, it is completely unnecessary because the data_event will retrigger on additional bytes or the rest of an uncompleted message.
I read alot of posts on this forum where people are concerned about the processing capacity of Netlinx Masters, in my experience the amount of processing that can be done on a single master using effecient code would suprise you. (NO JAVA!)
