Wake up
On panel AXD CP4/A there is an infra-red gauge how to deduce the panel from a sleeping mode I use this gauge, I should press constantly the screen that it has joined!
How to deduce the panel from a sleeping mode by means of infra-red gauges, result please an example...
  • vincenvincen Posts: 526
    Just go in Setup of Panel and you should be able to activate wake-up of panel by mean of gauge ;)
    Vinc
  • LehaLeha Posts: 37
    Question! I
    Vinc?n
    I expose on the panel activation by means of the gauge, but it does not work, again it is necessary to press a finger in the screen for a conclusion from a sleeping mode.
    Have a look at page 34 of that document http://www.amx.com/techdocs/0362655.pdf You should get button INFRARED WAKE button activated ;)
    Hope it helps
    Vince
