RMS 3.0 Web Error
I have just installed RMS 3.0 on my server and when I go to the web page I receive the following error. Any thoughts???
Server Error in '/RMS' Application.
The SiteMapProvider 'RMS_SiteMapProvider' cannot be found.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: The SiteMapProvider 'RMS_SiteMapProvider' cannot be found.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): The SiteMapProvider 'RMS_SiteMapProvider' cannot be found.]
System.Web.UI.WebControls.SiteMapPath.get_Provider() +1177472
System.Web.UI.WebControls.SiteMapPath.CreateControlHierarchy() +16
System.Web.UI.WebControls.SiteMapPath.CreateChildControls() +29
System.Web.UI.Control.EnsureChildControls() +87
System.Web.UI.Control.PreRenderRecursiveInternal() +41
System.Web.UI.Control.PreRenderRecursiveInternal() +161
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1360
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
Source Error:
Stack Trace:
This problem has been reported to AMX Technical Support and is currently being investigated. Once resolved, we will post an explanation on this thread.
Thank you!
