About RS-485 port controlling?(one way or two way)
Dear all,
I try to control a I/O sensing device called ADAM-4051
I must send command to 4051 via RS-485
But , the response is back via same RS-485 cord, too
How can I connect the pin between 4051(only D+ and D-) and AMX?
Thanks a lot.
  • JY, you didn't mention which AMX controller (or expansion box) you're trying to use, but if you look in the manual for it you should find pinouts for the RS232/422/485 ports. On a current NI-series controller, you would be connecting pins 1 and 9 together and using them both as connection "A", pins 4 and 6 togther and using them as "B", and pin 5 for ground. Since the manual for your device is using different designations for the RS485 signals you might have to try reversing the connection, but start out connecting "A" (pins 1 & 9) from the AMX to "D-" on the 4051, and "B" (pins 4 and 6) from the AMX to "D+" on the 4051. If the 4051 doesn't have a ground connection on the 485 port, you can probably get away without connecting pin 5 on the AMX to anything.
    In your code, make sure you use the right SEND_COMMAND to turn on RS485 on the port you're using. After that, you send and receive strings the same as you would with an RS232 device.
  • J.Y.J.Y. Posts: 34
    Chip,
    thanks for your reply.
    I connected pin 1 & 4 together
    and pin 6 & 9 together ,
    Am I right?
    I send_command 4051,'set baud 9600,n,8,1 485 enable' on data_event's online
    when I send_string to 4051
    It works fail.
  • J.Y. wrote:
    I send_command 4051,'set baud 9600,n,8,1 485 enable' on data_event's online when I send_string to 4051 It works fail.
    I don't know if this matters, but the syntax I always use is
    'set baud 9600,n,8,1,485 enable'
    note the additional comma.
    Mind you, I've managed to avoid enabling 485 so far, so I may have the syntax wrong.
  • J.Y. wrote:
    Chip,
    Am I right?
    It works fail.
    small mistake....
    connect pins 1-9 and 4-6
