Extron MLC 104 IP AAP
Marc Scheibein
Has someone experience with the above unit? Is it just using the Extron SIS protocol on network?
Application is 3 rooms which can be combined. Every room has some AV equipment and one of that Extron panels.
As long as the rooms are separated, the AV equipent of each single room is controlled from the Extron panel located in that room.
If the rooms are combined, the Extron panel of the 1st room should be "switched" to an AMX master as an input device, and the AMX master now controls the equipment of room 1 and some additional stuff. Panels of room 2 and 3 should be "disabled"
I never had such an Extron device, so any ideas are welcome.
Kind regards,
Kind regards,
I used one of these on a C
system. Basically, the Extron will send strings out the 232 port each time a button is pressed or the volume knob is turned. The SIS in the manual is exactly what comes out (SwPrs*1,SwPrs*2, VolUp,VolDn, etc.). Capture these strings in a buffer and use that data to control the AMX program.
Joe
Worked pretty good, but i couldn't get the feedback from the device i was controlling...
I have no experience with using an MLC unit for AMX control
