Early MVP?s vs. New MVP?s ? Wireless Issues
MRoed
in AMX Hardware
Has anyone else noticed that the wireless range of the MVP?s has been extended tremendously? The early MVP?s required an access point in practically every room we had an MVP. Some of our projects that have the early MVP?s still suffer from wireless issues. Momentarily they will drop the connection and buffer all of the button presses, then once reconnected they send out all of these commands at once.
Wireless site surveys show only one neighboring wireless network. I have tried both AMX and Linksys access points. I now have an access point in every room we have an MVP, but we still have problems. They are all setup on non-overlapping channels. At this point I think the only answer is to install new 802_11g cards and remove all but one access point. Is anyone else dealing with early MVP issues like this?
With the new panels, I can put a single access point in the basement and two floors up I still have connectivity. I have been told that the new panels will be shipping with the new 802_11g cards, but I am pretty sure that the panels I am using right now, with good results, do not have the 802_11g card.
Mark
Mark
Don't know if these newer 802.11B cards are still available (NXA-WC80211B/CF).
I don't know about new cards in other versions of the MVPs
If the data rate does not have 4 decimal places, it is one of the first NICs and qualifies for replacement - or at least they did in Australia...
The difference between the cards was quite significant.
Also, there have been several f/w releases that improve connectivity.
We are just about to upgrade a system to the 54g card - not for the speed, but connectivity.
...it's been a long time coming!
Yes yes YES! That's what happened! Argh argh ARGH! Thank you, I thought I was going mad or it was all the fault of my code.
Does anyone know if that applies in the US as well?
In residential applications I personally feel WEP is an adequate level of protection from normal free access to the wireless network by curious neigbors. In corporate applications where you have to deal with corporate spies or in institutional applications where you have to deal with mischievous techno geek students who will hack anything they can WPA is the better choice.
Supposedly with the use of freeware available on the Net there are programs that can crack the WEP 128 bit encryption in just over a million sniffed packets, or a few minutes of heavey network traffic which is a little scarry but in everyday use in residential applications when protection from roaming neighbors is all that's needed I still use WEP because it's easier and I feel is adequate protection.
Almost all my customers are residential so that's the way my thinking is geared if I was doing corporate or institutional I would most likely almost always use WPA.
Does anyone know the approx. date they started shipping the newer version 802.11b cards in the Modero Viewpoints?
