JAVA Issues for Web Control
I've got several Netlinx masters on a network I don't have lots of control over. When I try to use the web control, I never get past the Panja screen.
In the Java console, it appears to load all the graphics, says its done, and then it hangs on the following . . .
TpApp.loadpage: Starting Connections
I'm using the older version of JAVA recommended elsewhere on the forum, but I've tried this from 3 separate computers and I'm not getting anywhere on any of them. Someone mentioned in another thread that they'd found it was a port forwarding issue, but didn't expound upon how they had fixed it. Anybody able to clear that up and give me a few more specifics?
Thanks in advance
Thanks in advance
http://www.amx.com/techsupport/techNote.asp?id=790
Charles
Interestingly enough, it works perfectly now in Internet Explorer yet crashes Firefox every time. Not a big deal, but certainly strange . . .
If I remember correct, also v2.20 was possible to do the Java based webcontrol.
In your special case if updating from v2.20 to v3, it may be required to update to v2.32 before you can update to v3. In both of these steps, the download will fail after 3 of 4 parts. This is normal. Reboot the master manually and update again, now all 4 parts will be loaded. Like told before with the technote, don't forget to push up the Duet mem to about 3-5 MByte, to get the v3 webserver run properly.
The system as it stands has nonfunctioning webcontrol. I did not install it. It is out of warranty. The company that did install it, put up webcontrol, but it basically crashes everything and never finishes loading.
I'm just in the beginning stages of trying to troubleshoot this, but my first thought was that upgrading to Duet and setting enough memory to run it would be a good start. Upgrading the firmware is where I almost always start when I'm having trouble with any hardware, so I'm trying to apply that to AMX as well.
Reading the tech note, I thought there might not be enough memory allocated for this bigger touchpanel file, so I went to SET DUET MEMORY. Thats when I found out I was dealing with pre duet firmware, so I was trying to figure out how to update the firmware.
Did you get you Web Control to work ? and how ??
Sometime ist does, sometimes not, could be memory related, bad enough that a standard issue like "insuficient memory" does crash th system instead of prducing an "insuficient memory" warning.
Did an update or firmware upgrade resolve it ?
