length_array() issue
Gday all,
I've noticed some "interesting" behavior with length_array(), which had me baffled for several days. It doesn't seem to like constant strings. If it is called several times on the same constant string, the master locks up (including bringing down comms to the master). I've been too familiar with the PRD switch & power plug while trying to figure out this issue.
An example:
PROGRAM_NAME='LengthArray test'
dvRelay = 5001:8:0
dvTp = 128:1:0
DEFINE_CONSTANT
//char cDelimiter[] = ';'  //Can lock up the master
char cText[50]
char cDelimiter[] = ';'  //Works fine.
//constant char cDelimiter[] = ';'  //Can lock up the master
button_event[dvTp,1]{
 push:{
  if(length_array(cText) > 0){
   wait 10 'test'{
    //Works fine.
//    cText = left_string(cText, length_array(cText) - 1)
    //Can lock up the master if cDelimiter is a constant string.
    cText = left_string(cText, length_array(cText) - length_array(cDelimiter))
    send_command dvTp, "'!T',1,cText"
button_event[dvTp,2]{  //Restore
 push:{
  cText = 'The quick brown fox jumps over the lazy dog.'
DEFINE_PROGRAM
When using a constant string & the truncate button [dvTp,1] is more than once, the master locks up. When using a non-constant string the master runs without issue.
So I guess my question is:
Is it bad practice to use length_array() on a constant string, or is it a bug with the compiler/master firmware?
I've sinced changed the offending line to something that works, but I thought others may be interested in this issue.
I'm using:
NI-3100 v3.13.339 / v1.12.140
NLS build 2.5.0.163 (NetLinx compiler 2.3.0.0)
Yours,
Roger
    I?ve never been exactly clear as to what the difference is but if you force the constant string literal into a constant char array, Netlinx will not die such a brutal death with LENGTH_ARRAY. So if you change:
    This:
    DEFINE_CONSTANT
    char cDelimiter[] = ';' //Can lock up the master ? and will
    To this:
    DEFINE_CONSTANT
    char cDelimiter[] = {';'} //Will not lock up the master
    Then life will be good.
    Thanks for the insight. I didn?t know Netlinx could be brought to its knees in this scenario, doesn?t seem right to me.
    And to answer your question, I don?t do a LENGTH_ARRAY on a CONSTANT since it will never change at runtime. Instead I do this:
    DEFINE_CONSTANT
    //Queue constants
    CHAR cQDelim[3] = '~!~' //delimiter for queues
    INTEGER nQDelimLen = 3
    And then I just use nQDelimLen instead of LENGTH_ARRAY(cQDelim) I don?t think your way is bad practice, I?m just lazy and don?t like to type more than I have to. :)
  • Array of constants.
    Joe Hebert wrote:
    DEFINE_CONSTANT
    I have alway put braces around character arrays that were defined as constants. This is the way it was taught in the AMX programming classes.
    I guess we now know why.
    DEFINE_CONSTANT
    CHAR cTEXT_ARRAY[4][] =
      {'Text1'},
      {'Text2'},
      {'Text3'},
      {'Text4'}
  • Single character strings AGAIN
    This appears to be yet another instance of the good old "not coping with single character strings" problem. Treat single character strings with enormous respect.
    Right on target Mark. If there is more than one character you can dump the braces and the master will not lock up. This falls into the category of things that make you want to go hmmm...
  • annuelloannuello Posts: 294
    Old thread, I know.... I was banging my head again while trying to do some html decoding. Here's one to try at home...
    send_string 0, "'Normal String length is: ',itoa(length_array('Normal String'))"
    send_string 0, "'Greater-than length is: ', itoa(length_array('>'))"
    send_string 0, "'Ampersand length is: ',    itoa(length_array('&'))"
    **sigh** Two hours to track down what I was doing wrong. Note to self: It doesn't matter how the string inside length_array() is declared - a constant of any flavour will bite you.
    For the record I'm using NLS v3.0.0.315 on v3.50.430 firmware.
    Roger McLean
    Swinburne University
