Why SEND_STRING not work
i not understand
If i send
send_string dvZpre1,"'W 1 1 1',13"
it work
but if i send
send_string dvZpre1,"'$57,$20,$31,$20,$31,$20,$31',13"
it not work
This string write in Parasound ZPre manual
  • Ascii / Hex
    send_string dvZpre1,"'W 1 1 1',13" :
    'W 1 1 1' thats an ASCII String
    ,13 thats an CR in DEC
    send_string dvZpre1,"'$57,$20,$31,$20,$31,$20,$31',13" :
    '$57,$20,$31,$20,$31,$20,$31' thats a HEX Command as an ASCII String...
    try without ' ' (Highcomma)
    i think thats should be work !
    send_string dvZpre1,"$57,$20,$31,$20,$31,$20,$31,13"
  • Ok
    it work
  • I have some problem with
    DEFINE_CALL 'SWT_KRAMER' (INPUT,OUTPUT)
    IF ((INPUT >= 0) AND (INPUT <= 8) AND (OUTPUT >= 0) AND (OUTPUT <= 8))
    SEND_STRING dvKramer,"$01,'$',ITOA(INPUT + 80),'$',ITOA(OUTPUT + 80),$81,$0D"
    What i do wrong ?
    What i do wrong ?
    You need $80 not 80
  • No - its not work
    SEND_STRING dvKramer,"$01,ITOA(INPUT + $80),ITOA(OUTPUT + $80),$81,$0D"
    Results Line
    13 :: String To [5001:1:1]-[$01129129$81$0D] - 01:46:21
  • I want send
    String To [5001:1:1]-[$01$81$81$81$0D]
  • mpullinmpullin Posts: 949
    I'm confused. You do know that $ is not the actual ascii character '$' right? the $ is just a sigil that signifies the following two numbers refer to a hexadecimal number. For instance $FF = 255.
    Oh and you're converting your additions to ASCII with ITOA(). You don't want ACSII characters. You want numbers. Try this: SEND_STRING dvKramer,"$01,(INPUT + $80),(OUTPUT + $80),$81,$0D"
  • OOO
  • banobano Posts: 175
    This one works for me,but it does create this compiler warning:
    C10573: String used as a CHAR value in a math operation
    send_string dvvidswitch,"$01,(80+itohex(input)),(80+itohex(output)),$81"
    itohex() produces a 2+ character string with ascii characters representing a value. For instance itohex(255) = 'FF', itohex(256) = '100', etc.
    it's useful for protocols which demand ascii characters representing hex strings. But if you're just trying to send hex stay away from this function.
    send_string dvvidswitch,"$01,($80+input),($80+output),$81" // I think this is what you're trying to do?
