485 Send Echo
Greetings,
When communicating with RS485 serial devices on Axcent 3 serial ports, the strings sent echo back on the receive even though 485 is enabled via the SET_BAUD command.
This does not occur on Netlinx serial ports when 485 is enabled. Is there something that I am missing to prevent the echo on Axcent 3 ports?
Thanks!
Thanks!
Does this still occur if you remove the field cabling? (particularly from the device end)
I don't believe I've seen this before and am wondering if there is a wiring issue here perhaps...
Just a thought - you may have done it already!
The echo occurs because the send and receive pairs at the Axcent 3 are tied together as they have to be for 485. Disconnecting the device end still shows the echo, just not the return data which appears after the echo.
