Master lost connection
I am working with NI-3100 and netlinx 2.5
My controller losting connection to Netlinx every few minutes if not in action.
The TP connection is working ok and sending commands to it, so its not the network problem.
All I need to do is to reboot it, and its ok. then I can connect transfer etc...
But after some time I must reboot it to connect with it again..
Its happening only in one controller.
Both controller have the same firmware update (2105-04_NI-X100_Master_v3_21_343.kit)
My router is Linksys wrt54g
Thanks for any help
Ady
  • GSLogicGSLogic Posts: 562
    Under: Settings -> Master Communications -> Edit Settings
    Try unchecking the check box in the TCP/IP Properties:
    Automatically Ping the Master Controller.
  • adysadys Posts: 395
    Thanks I will try that
    ady
