Time Manager fails to contact server
Rich Abel
I have two Netlinx systems on the sam LAN that run the Time Manager application for clock synch and to generate sunrise and sunset times.
One system is a NI-3000 with master firmware V 2.31.141 and device firmware V 1.00.118. On this system it works perfectly.
The second system is a NI-3000 running master firmware V 2.32.148 and device firmware 1.12.140. This system is newer and uses some Duet modules, thus the difference in firmware. The system fails to contact a timeserver, generating the log entry:
10: 02-07-2007 WED 16:58:20 SocketManager UNKNOWN HOST: utcnist.colorado.edu
which sounds like a DNS problem. Yet, as I mentioned at the outset, both systems are on the same LAN, have the same gateway, same DNS entries, etc.
Anyone run into this before? I wonder if the Duet-enabled systems have some differences?
Appreciate any suggestions or ideas to resolve this.
Rich Abel
ACE Designer / Programmer
Cello Technologies - Seattle
Rich Abel
I once had a weird problem like this, and could not figure it out. Not only would the time manager not connect, but my dynamic DNS module wouldn't connect, and I could not remote in to the master with NAT. So I reset the master to DHCP, let it connect that way, then went back and changed it to a static IP. It all worked after that. MY settings before and after this procedure were identical, yet something changed to make it start working again. I can only guess there are some hidden settings that DHCP will clear.
Thanks. I'll try that and see.
The time manager code refers to a list of timeservers
"Leave blank to read from time sevrer file (time/nist_svr.lst)"
any idea where I would find this list? I don't see it on my local PC.
Rich
