Ethernet problems
                    I am currently trying to hookup an NXT-CV10 to an NI-3000 via a crossover ethernet cable.  In the touchpanel, I have set the DHCP/Static field to Static and assigned it a static IP.  The Master Connection is set to Ethernet and the Mode is URL, and I have set the Master IP to the IP address I got from the NetLinx Diagnostics program.  The panel IP is 10.176.14.199 and the master is 10.176.14.202.
I have verified that the cable is in fact a crossover; I was able to successfully access the master from my PC using the same cable. However, when I plug in the cable, I never see any LEDs blink, and I can never get the touch panel to appear as a device in NetLinx Studio or the Diagnostics program ( I am simultaneously connected to the master via RS-232 to my PC ).
Is there something basic I'm missing here? I am still new to this, so I want to make sure I'm passing any kind of "idiot test" you guys might know of. Thanks for any help you can offer.
You?re settings sound fine. However, I?ve never wired it the way you explained and if I understand you correctly, I don?t think it will work.
The standard route to take is to plug in your NI master and your touch panel into a switch that is on the same network as your PC. I think you can pick up an 8 port Linksys switch for under $75.
I have ran into trouble a couple times and this always seems to works.
Try setting your computer to have a static IP 1 digit below the NI.
NI = 192.168.1.11
PC = 192.168.1.10
What's your subnet mask?
255.255.255.0
Doesn't that mean you have a problem with the physical connection rather than the IP addressing?
When I disconnect the network cable, both LEDs are dark.
When I have good IP comms, I see an orange and a yellowygreen LED lit up on my NI700.
When I set a random IP address and reboot, both are still on.
Just a reminder: cross-over cable has never been something official in Ethernet world, it works often but not always as you are never supposed to link two Ethernet devices just like that, it must pass through at leat an hub, or better a switch
Vinc
I put in a switch, now it works great! Thank you so much for your swift and accurate responses.
