Mvp-8400 Button Images
Is anyone aware of a way to (via code) assign a particular image to a button?
I have been playing aroung with some of the embedded button commands
(^BMF, ^BMP, etc) but when I send the command, it just eliminates the graphic from the button. It never changes to the new graphic image that I place in the command.
I decided to assign several background graphics to specific slots in TPD4,
but I have not seen a command to tell a button to display the graphic image
from a specific slot#.
There must be something simple that I am doing wrong.
Anybody done this succesfully before?
Thanks.
Thanks.
I guess my head is still in the G3 era sometimes.
I finally figured out that I needed the ^ICO command because
the slots are considered icons, not bitmap images in TPD4.
For this particular project, I wanted a way for the client to select which vendor would
be using his conference center. So I placed all my vendor logo background images
into slots, and then the client can (from his tech panel) select which logo will
be the background image for each panel in any of the rooms.
Using the dedicated slots seemed to be the only organized method I could see to
have everything inside the panel.
I had considered using dynamic imaging from their web server, but they felt more
comfortable with the images loaded directly into the MVP-8400.
Thanks for the reply.
To get around this I just standardized my slot allocations. In some situations I like the ability to put a play icon on a custom button without having to create a transparent button for the play icon.
