serial protocol problems - help needed
Hi all
I am working with ARCAM tuner with rs232 protocol.
I am trying to send this command:
Quote from the protocol:
Select a preset radio station.
Example
Command/response sequence to select preset 12:
COMMAND: 0x21 0x13 0x01 0x0C 0x0D
RESPONSE: 0x21 0x13 0x01 0x01 0x0C 0x0D
When I am sending this command from the telnet for preset 2 like this:
send_string 5001:4:1,$21$13$01$02$0D
its working.
from my program - nothing...I can see the netlinx port number 4 tx led is working but the tuner is not responding.
looking at the notification windows shows the same command - (from some reason it shows the $21 character '!' instead of value)
Same happen to me in other devices too of Kramer. there must be something I am doing wrong here....
I tried everything I know, several string formats, I even made a button event to set the baud rate just to make sure its set.
BTW this device is not sending ONLINE event when its starts, only string event.
Attached are my program and notification window capture.
Thanks for any help
Ady
Example
its working.
Thanks for any help
Ady
here is the main program
PROGRAM_NAME='STUDYROOM'
(* FILE_LAST_MODIFIED_ON: 04/05/2006 AT: 09:00:25 *)
(* System Type : NetLinx *)
(* REV HISTORY: *)
$History: $
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
// Study room system - > system 1
// my touch panel devices
dvTPStudyRoom = 10001:1:1
// (controller:device:system)
// Serial devices
dvSONYFDW32 = 5001:1:1 // LCD TV PRO serial
dvDENON780 = 5001:2:1 // TAPE DECK
dvDENON3910 = 5001:3:1 // DVD
dvARCAM = 5001:4:1 // TUNER
dvVS1616A = 5001:5:1 // audio matrix
dvVP84ETh = 5001:6:1 // video matrix
dvYES1 = 5001:9:1 // YES SET TOP BOX
dvYES2 = 5001:10:1
dvYES3 = 5001:11:1
dvSONYKDL52 = 5001:12:1 // LCD TV BIG IR
dvSONY640 = 5001:13:1 // VCR IR
dvGEFENHDMIMatrix = 5001:14:1 // HD matrix
vdvDenon3910 = 41001:1:1
dvDebug = 0:0:0
//send_string 5001:4:0,$21$13$01$02$0D
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
include 'tunerarcam.axi'
include 'dvddenon.axi'
include 'kramer_vs1616'
include 'kramer_vp84'
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* Initialize Devices *)
SEND_COMMAND dvVS1616A, 'SET BAUD 9600,N,8,1'
SEND_COMMAND dvVP84ETh, 'SET BAUD 9600,N,8,1'
SEND_COMMAND dvARCAM, 'SET BAUD 19200,N,8,1'
(* THE EVENTS GO BELOW *)
DEFINE_MODULE 'Denon_DVD3910_Comm_dr1_0_0' COMM1(vdvDenon3910, dvDENON3910)
DEFINE_MODULE 'Denon_DVD3910_UI' TP1(vdvDenon3910, dvTPStudyRoom, nTP_BUTTONS, nTXT_BTN)
The Arcam Module:
PROGRAM_NAME='ARCAM'
(*{{PS_SOURCE_INFO(PROGRAM STATS) *)
(* FILE CREATED ON: 10/02/2001 AT: 09:51:02 *)
(* FILE_LAST_MODIFIED_ON: 10/03/2002 AT: 08:38:12 *)
(* ORPHAN_FILE_PLATFORM: 1 *)
(*}}PS_SOURCE_INFO *)
(* System Type : Netlinx *)
(* REV HISTORY: *)
//# File : Rcvr_Tp.axi
//# Desc : This file handles tuner audio functions for the touch panel.
//# Notes : None.
DEFINE_CONSTANT
// TUNER TP Button constants
TUNER_PRESET01 = 1
TUNER_PRESET02 = 2
TUNER_PRESET03 = 3
TUNER_PRESET04 = 4
TUNER_PRESET05 = 5
TUNER_PRESET06 = 6
TUNER_PRESET07 = 7
TUNER_PRESET08 = 8
TUNER_PRESET09 = 9
TUNER_PRESET10 = 10
TUNER_POWER = 15
//Tuner commands
Power_button = '$21$00$01$01$0D'
Preset01 = '$21$13$01$01$0D'
Preset02 = '$21$13$01$02$0D'
Preset03 = '$21$13$01$03$0D'
Preset04 = '$21$13$01$04$0D'
Preset05 = '$21$13$01$05$0D'
Preset06 = '$21$13$01$06$0D'
Preset07 = '$21$13$01$07$0D'
Preset08 = '$21$13$01$08$0D'
Preset09 = '$21$13$01$09$0D'
Preset10 = '$21$13$01$0A$0D'
VOLATILE INTEGER nTPTunerBtns []=
TUNER_PRESET01,
TUNER_PRESET02,
TUNER_PRESET03,
TUNER_PRESET04,
TUNER_PRESET05,
TUNER_PRESET06,
TUNER_PRESET07,
TUNER_PRESET08,
TUNER_PRESET09,
TUNER_PRESET10,
TUNER_POWER
BUTTON_EVENT[dvTPStudyRoom, nTPTunerBtns]
STACK_VAR INTEGER nBtnIndex
nBtnIndex = GET_LAST(nTPTunerBtns)
SWITCH(nBtnIndex)
CASE TUNER_POWER:
send_string dvARCAM, Power_button
CASE TUNER_PRESET01:
send_string dvARCAM, Preset03
send_string dvDebug, Preset03
CASE TUNER_PRESET02:
send_string dvARCAM, Preset02
CASE TUNER_PRESET03:
CASE TUNER_PRESET04:
send_string dvARCAM, Preset04
CASE TUNER_PRESET05:
send_string dvARCAM, Preset05
CASE TUNER_PRESET06:
//send_string dvARCAM, Preset06
CASE TUNER_PRESET07:
send_string dvARCAM, Preset07
CASE TUNER_PRESET08:
send_string dvARCAM, Preset08
CASE TUNER_PRESET09:
send_string dvARCAM, Preset09
CASE TUNER_PRESET10:
send_string dvARCAM, Preset10
} // END OF - SWITCH
} // END OF - PUSH
} // END OF - button event MainSetup
DATA_EVENT[dvARCAM]
COMMAND:
SEND_STRING dvDebug,"'ARCAM COMMAND'"
ONLINE :
SEND_STRING dvDebug,"'ARCAM ONLINE'"
STRING:
SEND_STRING dvDebug,"'ARCAM STRING'"
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
Thanks for any help
Ady
For example:
The single quotes make it ASCII. I'm not certain how to do this in the DEFINE_CONSTANTS section; I would do it in DEFINE_VARIABLES as:
CONSTANT CHAR Preset01[] = {$21,$13,$01,$01,$0D}
This will store each string by the HEX value, which I am presuming your protocol requires. If it really does what the ASCII encoding of the HEX, well, never mind
I was debugging all day cause I send wrong values???
I suspect the values, but I tried different version with no sucess, but not inside variables.
Why does the notification windows shows the same?
Thanks a lot, I will check it asap on the morning
Ady
it's strange that the notification window showed '!' instead of $21
It does that when it's sending out "real" hex strings, but since you were sending out ASCII strings i'm really curious what's happening.
Did you get the '!' when sending from Terminal window or from your program?
It would be a nice option to have it display all hex if desired. Feature request?...
Just thought I'd give you another idea.
Try this in your code, it is much easier to read and faster to code$$$
From the telnet ( you can see it in the attached picture at the begining of the thread)
You can see that I am listening to the online event too, and its never gets there.
when the arcam device up its sends STRING data event and not online...
is this is normal for devices or am I doing somthing wrong?
Since that online event happens shortly after the processor reboots, you're probably just not reconnecting to the master in time to see the "ARCAM ONLINE" message...
thanks
