powerpoint wirelessly
jessep
My client would like to display their computer screen on the projector, from a wireless laptop. The projector is wired for component video back to the equipment rack. Is there a piece of equipment that can reside in the rack that will take the video from the projector over 802.11 and output component to the projector?
I know some products from D-link exist but I believe they only accept video, pictures, and audio, and come with some software interface. I just want a raw way to display the computer.
The only thing I know of that does this is People+Content IP from polycom. but that is way overkill for this application.
- The projector is wired for component video back to the equipment rack.
Do you mean the projector has a component output that for some reason is wired to a receiver in your rack, or do you mean the component signal from the rack to the projector.
-...that will take the video from the projector over 802.11 and output component to the projector?
What do you mean by '...video from the projector...'
Your answers might clear things a bit.
The only thing I can think of is some type of video capture program that will output to a web server, then pick that up in the rack and re-send it to the projector. I know of a program (FRAPS) that will capture it to disc, but not specifically to a server, and you will likely need another computer to pick it up. Your laptop is going to have to pretty powerful to do this as well. I'm not sure, in the end, that doing it that way would be practical.
http://sewelldirect.com/wireless-pc-to-tv.asp
I didn't read up on it but I suppose you could connect this to a VGA output on the laptop and put the receiving end at the rack switcher input.
The down side if this works at all would be having this little box connected to you lap top and supplying it power some how.
Other wise the rack mounted PC runnig the power point app with the Laptop controlling it via VNC sounds like the cleanest approach.
i KNOW there is a product that does this. We installed it at a site.
Its a Wifi Access Point which has a VGA and an audio(!) output.
It also has an Ethernet input, so you can still be connected to the network (since you can't connect to 2 wifi networks at the same time )
I'll look if i can find the manufacturer and type of the product
edit:
w00p, i found it
http://addlogix.com/peripheral_sharing/echoview.htm
look at the other products, they have some NICE stuff
i have tested one, and they work pretty well. The only drawback is that they feel a bit cheap
