Gefen IR codes
I tired to learn 4x4 HADI matrix remote control with no success.
AMX IR learner don't recognize it, and also with RTI learner - no success....
is there any way to use those codes in IR?
http://www.gefen.com/kvm/support/Slim%20Remote%20Control%20Unit.pdf
I tried to enter this codes as discreet codes, but I got format error.
I got this link from Gefen Support after asking for IR code, they are saying this is what everyone is using and should be no problems...
Ady.
Ady.
This is what I tired to do with RTI capture hardware, with no success too...
this remote is very stubborn ...
That unit has rs232 with very easy commands.
But I managed to learn it with the RTI and to use the code in the IREDIT
I am attaching it just in case that anyone will need it
BTW - how can I add it to the AMX InConcert?
They are usually pretty good about capturing difficult remotes in a timely matter. The engineers throw it on the scope and email an RTI library file to you with the codes. Then you just need to copy&paste the Hex values into IrEdit.
... or ... use the 232 control that was just mentioned.
Sorry I don't have direct experience with the piece you are asking about, so this is a general reply.
Its ok now, and I added the ir file.
