Multiple Module Instances
Just a note to those who write modules. There is a problem when using multiple instances of the same module. In these cases, the HOLD: portion of BUTTON_EVENTs is only generated in the first module declared.
The current workaround is to just copy the module and rename it with a unique name for each instance. Engineering is currently working on a fix.
One side note, If you use different devices generating the HOLDs for the modules, this does not exhibit any problems.
P.S.
I think this may have been discussed, but I didn't find anything in a couple of searches for the info.
P.S.
Thanks to share that info so we don't loose time if we encounter the issue
Vince
There is no threading, all the NetLinx code that you write simply takes its turn, presumably in the order it was instanced in the mainline.
This has a number of interesting implications:
(1) You can be sure that all operations are atomic; you don't have to worry about one piece of data manipulation being part-completed when another process jumps in.
(2) If you write an infinite loop or some heavy-duty code, nothing else runs until it has finished. So where practical do the heavy lifting in incremental chunks rather than all at once to avoid latency for everything else. (I can't say I've ever actually done that.)
(3) (I'm guessing this observation is an implication of the above) if you "send_string 0" a LOT of text, everything slows down a LOT.
I'm sure others have more to add.
