Netlinx Diagnostics
I can use diagnostics within Studio no problem but I when I launch Netlinx Diagnostics 1.14 it fails to connect using the same settings as Studio. Anyone else have that problem?
Thanks.
  • Not sure if NetLinx Diagnostic Tool is working with the current masters (NI-x100) in general.
  • glr-ftiglr-fti Posts: 286
    One of the masters I am trying to get to is a NIx100 but the other is a NIx000 and I have the same problem. I have gotten to the NIx000 with the tool in the past.
  • vincenvincen Posts: 526
    Did you check about login/pass if you have activated security on NetLinx master ?
    Also don't forget you can't be connected in debug with two different software in same time as master is supposed to accept debug system from only one system at a time ;)
    Vince
    It might be a firewall setting on your PC; Studio is permitted to go out, but Diagnostics isn't.
    The problem was with security activated on the master.
    Thanks for the ideas.
