Baluns for AV inputs
TonyAngelo
In the FAQ (page 3) for the UDM-1604 it says that the Extron NVT314A & NVT418A baluns can be used to input composite in the four AV inputs on the front.
Are there any other baluns that will work that anyone knows of.
It depends on what they are doing - if it's just an unbalanced to balanced adapter, pretty much anything will work that will pass the entire frequency range.
We have just suceeded using Extron MTP R range of products i also believe you could use some passive baluns but beware they tend to require odd ball connections on the RJ45 leads
