PictureTel APTZ-1N camera
This is a much outdated PTZ camera that was used with the
PictureTel codecs.
I have acquired this unit and my client would like to attempt
to control this via IR as a stand alone PTZ camera.
The camera unit has an IR pickup sensor on it.
I have tried every PTZ driver that I have (Sony, Canon, PictureTel, Polycom).
I dont know if this particular camera has to talk the codec to operate.
Has anyone ever controlled one of these as a stand-alone PTZ via IR.
If so, whose driver did you utilize for control.
Thanks for any input.
PictureTel codecs.
1
I was considering making a cable to see if the camera
possibly listens to the VISCA protocol.
I was not sure if the 8p connection is standard or not.
Pin 1 - RX
Pin 2 - TX
Pin 3 - GND
Pin 4 - -12V
Pin 5 - GND Svideo
Pin 6 - SVideo Signal
Pin 7 - +12V
Pin 8 - Svideo Signal
876
5 43
21
I can upload the code if you want to go through it and test it out.
Thanks.
If you need more, you can get a software serial sniffer and check out this website:
www.camerapad.com
this will also work with picturetel PTZ-N2
