Define_Function Variables
Spire_Jeff
Not sure if this has changed or if I have just never run across this, but it seems that passing variables to a function is really just passing a reference to the main variable. This means that if you do any manipulation of the passed variable, it will change the value of the original variable. For example:
The first string sent would be: nVAR = 5 and nRESULT = 2
The second string would be: nVAR = 5 and nRESULT = 0
I know this is a common concept in other programming languages, I just didn't recall ever encountering this in Netlinx (but it's possible I never performed ops on the variable passed). This is just a heads up to anyone that might have weird results coming from a function
DEFINE_FUNCTION INTEGER CHECK_FOR_SOMETHING(INTEGER nSOMETHING) { STACK_VAR INTEGER nCNT; WHILE (nSOMETHING >100) { nSOMETHING = nSOMETHING -100 nCNT++ } RETURN nCNT; } . . . nVAR = 205 nRESULT = CHECK_FOR_SOMETHING(nVAR) SEND_STRING 0,"'nVAR = ',ITOA(nVAR),' and nRESULT = ',ITOA(nRESULT)'" nRESULT = CHECK_FOR_SOMETHING(nVAR) SEND_STRING 0,"'nVAR = ',ITOA(nVAR),' and nRESULT = ',ITOA(nRESULT)'"
Try learning Ruby. When you assign the value of one variable to another, what you are actually doing is copying a reference to an object from one to the other. I get dizzy thinking about it.
Isn't that the same as passing the result of an expression like CHECK_FOR_SOMETHING(1+2)?
DEFINE_FUNCTION INTEGER Check_For_Something(Integer nSomething)
Local_Variable Integer nLocal,nCnt // Or use Local_Variable
nLocal = nSomething
While (nLocal < 100)
nLocal = nLocal-100
nCnt++
Return nCnt
