FastSettleBus ???
Greetings,
I have a Netlinx-based system with an Axcent 3 Pro as a slave. Occasionlly all of the devices of the Axcent 3 drop offline and immediately come back. The message FastSettleBus is in the log, very close in time to the Axcent 3 Pro drop-off.
Any ldeas exactly what FastSettleBus means or what may cause an Axcent 3 Pro to go offline then right back on?
Thanks!
    I think FSB is usually related to iffy Axlink wiring, or other devices on the bus causing noise/collisions. Is there anything else on the bus besides the Ax3?
    Did you look at the 'tech support' online. It gives a listing for this problem. Might not be your issue but always worth a look.
    Yes, 16 Mio keypads and several tv controllers.
    I wish there was a way to monitor the Axlink bus in real time to verify the itegrity of the wiring, devices, etc,
