Switching Video modes
What kind of command would I use to switch Video modes, video to s-video back to video using the same button. I have try the below code but it stays in S-video mode. It will go from Video to S-video but remain there inless I go to RGB and start over.
IF (!Video_Input)
send_string dvPlasma,"'@G',13"
wait 20 send_string dvPlasma,"'%A1012',13"
SEND_STRING 0, "'%A1012',13"
Off [RGB_Input]
On [Video_Input]
Else IF(Video_Input)
wait 20 send_string dvPlasma,"'%A1014',13"
SEND_STRING 0, "'%A1014',13"
On[Video_Input]
Off [RGB_Input]
On[Video_Input]
Off [RGB_Input]
IF (!Video_Input)
Off [RGB_Input]
On [Video_Input]
On[Video_Input]
Off [RGB_Input]
On[Video_Input]
Off [RGB_Input]
IF ( NOT A ) { }
ELSE IF ( A ) { }
ELSE IF ( A ) { }
I'm not 100% sure what you're trying to do or what all those variables are for, but you should rethink your logic.
Button press 1:
Goes to Video mode
Button Press 2
Goes to S-Video mode
Button Press 3
Goes back to Video mode.
and the cycle repeats every time I hit the button.
You are using "Video_Input" as a test. You are turning it on, but not off. So the code block for Video will run only the first time, but not after. You need to change "Video_Input" to off when you are going to S-Video. Also as mpullin says, you don't need the last block of code.
switch(nRGB_VAL){ case 1: // set input to RGB2 nRGB_VAL = 2 break case 2: // set input to RGB3 nRGB_VAL = 3 break case 3: // set input to RGB1 nRGB_VAL = 1 break default: nRGB_VAL = 1 // so it doesn't get stuck break }Hey, I am really confused on where the nRGB_Val 1,2,3 are set at. I dont understand how do define it. I believe it to be a Variable because it would change cause of RS-232 codes that need to be sent. Is that correct? Are the cases going to look like this:
switch(nRGB_VAL)
case 1:
nRGB_VAL = 2
wait 20 send_string dvPlasma,"'%A1000',13"
SEND_STRING 0, "'%A1000',13"
On [RGB_Input]
break
case 2:
nRGB_VAL = 3
wait 20 send_string dvPlasma,"'%A1001',13"
SEND_STRING 0, "'%A1001',13"
On [RGB_Input]
break
case 3:
nRGB_VAL = 1
wait 20 send_string dvPlasma,"'%A1002',13"
SEND_STRING 0, "'%A1002',13"
On [RGB_Input]
break
default:
off [RGB_Input]
break
Hey it works, Thank you so much... I figured something out with help of course. Thanks again.
