on-screen countdown
I need a count-down on a TP-4 device.
The idea is that someone pushes a button and a countdown begins (20, 15 and 10 minutes, depends on the function needed). When it reaches zero it starts to count up again to show minutes and seconds passed the countdown time. The countdown is visible on the screen.
Has anyone done something like this? I have not worked with time functions so this is so it would be helpful if someone could point me in the right direction.
I have found, with this method, it is a good idea to have a button on the popup (I generally hide it in a corner), to close the popup in case a communications glitch prevents the @PPF from going through for any reason (more an issue with wireless panels than wired).
