how do u work with netlinx modules!!
galaye
i never did so how to add a module and how to call him!!!
i know there a good volume module that simplfy the option to press and as long as pressed the volume goes up and not every press like i do!!
thanks again
thanks again
The <> brackets are not part of it, that's just to show the data in there changes according to your needs and the module itself. The INSTANCE part is if you have multiples of the same module so the compiler can tell them apart. The parameters should be spelled out in the module's documentation.
You shouldn't need a module just for volume control. If it's an RS-232 device, put a HOLD handler in the button event with a time and the repeat keyword. If it's IR, just use TO on the IR port.
i now prees and every press it work...
i never tried with hold can u give sample...like u gave with the define strart...
thanks alot!!
Here's an example for a BiAmp level control. Just set your volume buttons in TPD4 to increase or decrease a level. Use the "Level Control Type" property of a button.
LEVEL_EVENT[vdvTPa,1] //PROGRAM VOLUME CONTROL
IF(iVOLUME_MUTE[1])
SEND_STRING dvDSP,"'SET 1 FDRMUTE ',sPGM_IDX,' 1 0',$0A"//UNMUTE
iVOLUME_MUTE[1] = 0
iVOLUME_LEVEL[1] = LEVEL.VALUE
SEND_STRING dvDSP,"'SETL 1 FDRLVL ',sPGM_IDX,' 1 ',ITOA (iVOLUME_LEVEL[1]),'0 ',$0A" (* FADER LEVEL IN *)
Heres the help from NLS on HOLD;
BUTTON_EVENT [(DEVCHAN[ ])]
// Push statements go here
RELEASE:
// Release statements go here
HOLD[TIME]: or HOLD[TIME, REPEAT]:
// Hold statements go here
thanks i will use it
and it gives me syntax error ....
when i wite the sytax:
BUTTON_EVENT[TP,191]
SEND_STRING MIXER,"'SV 4 180',13"
RELEASE :
HOLD[5,[REPEAT]]:
I DONT know way...
also it written like the help saies and stil sytax error C10201
I DONT KNOW WAY
THANKS
HOLD[5,REPEAT]:
The brackets in the help entry, confusingly, mean that the REPEAT part is optional.
Jeremy
i have tried without
try one:
HOLD[5,REPEAT]:
try 2:
HOLD[5]
try 3:
release
HOLD[5]:
send_string....etc
and still returns syntax error and i put the sentence out with (* and*) and no errors
i f u can see and check wht i do rong!!
--D
Now I Will Try In The Conferance Room And I Will Much Gratefull!!
