How can I feedback the RS-232 response to TouchPanel?
I want to feedback the RS-232 response from the devices (Projector for example). Where should I read the RS-232 response message?
Sample code would help a lot. Thanks
  • I suggest that you look in the code that I sent you yesterday.
  • adysadys Posts: 395
    DATA_EVENT[dvMLPreAmp] // your rs232 device
    ONLINE:
    SEND_COMMAND dvMLPreAmp,'SET BAUD 38400,E,8,1' // according to your device
    STRING:
    char cLCD_DATA[64];
    cLCD_DATA= DATA.TEXT
    // do what ever you like with the text...
  • You can monitor the response strings from a device using Netlinx Studio. Enable diagnostics and enable notifications. While these are turned on you'll be able to see strings being returned (except if the device returns a $00, then the rest of the string after the 'null' won't show).
    Also, a useful tool is to use commands like SEND_STRING 0, " (*stuff to send to screen here*) ". Outputs from this command will show up in the diagnostics tab. I use it a lot when parsing response strings to make sure I'm getting the expected result.
    EXAMPLES:
    SEND_STRING 0,"'Command Received O.K.;'"
    SEND_STRING 0,"'sRESPONSE_QEUE = ',sRESPONSE"
    SEND_STRING 0,"'SPACKETTYPE =',sPACKET_TYPE"
    DATA_EVENT [dvDEVICE]//RESPONSE STRINGS RECEIVED FROM DEVICE
       STRING:
    		stack_var char cur_cmd[18]
    		sRESPONSE_QEUE="sRESPONSE_QEUE,data.text"
    		send_string 0,"'From data event in module for dvDEVICE: sRESPONSE QEUE =', sRESPONSE_QEUE,'  DATA.TEXT = ', data.text"
    --John
  • In re-reading your question, it looks like you're trying to send the device response to the touchpanel. If you're trying to send to the touchpanel, then you'll need to create a button in the touchpanel with an address port and address code. Then you could use a SEND_COMMAND to send the string to the button you created on the touchpanel.
    ex.
    SEND_COMMAND dvTP,"'@TXT',1,'STRING = ', sRESPONSE_STRING"
    --John
  • Or use ^TXT
    Or you can use the ^TXT command (G4 command)
    SEND_COMMAND dvTP, "'^TXT-1,0,RESPONSE STRING = ',sRESPONSE_STRING"
    --John
  • flcusatflcusat Posts: 309
    Not trying to hijack the thread but how could you use the feedback string to condition a particular sequence in a macro? For example send the power command plus the input command if the device is off but only the input if it is on.
  • HedbergHedberg Posts: 671
    something like:
    button_event[dvTP,nSelectInputx]
      push:
        IF(!nPwrStat)
          send_command dvDevice,"'turn it on',13" //if it's not on, turn it on
          nPwrStat = 1 //you can control this parameter with queries and responses if the device supports it
          nWarmed = 0
          wait 300  // wait until the device is ready to handle an input change -- maybe 30 sec for a projector
              nWarmed = 1
        wait_until nWarmed
          send_command dvDevice,"'Select Desired Input',13"
    I've not tested the above, but it should give you the idea.
    Thanks for the input.
