xap dialer
Anybody can gimmi a few pointers on how to handle a xap dialerf system? as in syntax variables and so forth and dunno how to umm store pressed buttons until the call button is executed :(
  • dthorsondthorson Posts: 103
    First you have to create a string from a keypad, then send it.
    Check out:
    cKEYPAD_ENTRY = ITOA(BUTTON.INPUT.CHANNEL - 100)
    the buttons on the keypad are 100-110
    so subtract 100 and assign that value to a keypad variable, then update the cPHONE_NUMBER. Then send the value to the touch panel in the dial button event.
    You can also delete and clear the phone number.
    DEFINE_CONSTANT
    // ATC Functions
    atcDEV_XAP800	= '#5'	//XAP 800
    atcDEV_XAP400	= '#7'	//XAP 400
    atcDEV_ID		= '0'
    atc0				=	100
    atc1				=	101
    atc2				=	102
    atc3				=	103
    atc4				=	104
    atc5				=	105
    atc6				=	106
    atc7				=	107
    atc8				=	108
    atc9				=	109
    atcSTAR			     =	110
    atcPOUND			=	111
    atcCALL_ANSWER		=	112
    atcHANG_UP			=	113
    atcFLASH			=	114
    atcCLEAR			=	115
    atcBACKSPACE		=	116
    atcANSWER			= 	118
    VOLATILE CHAR cXAP_RX[50]
    VOLATILE INTEGER iPHONE_OFF_HOOK
    VOLATILE CHAR cKEYPAD_ENTRY[1]
    VOLATILE CHAR cPHONE_NUMBER[255]
    DEVCHAN devATC_KEYPAD[] =
    {{vdvTPd,atc0},{vdvTPd,atc1},{vdvTPd,atc2},{vdvTPd,atc3},{vdvTPd,atc4},
     {vdvTPd,atc5},{vdvTPd,atc6},{vdvTPd,atc7},{vdvTPd,atc8},{vdvTPd,atc9},
     {vdvTPd,atcSTAR},{vdvTPd,atcPOUND}}
    BUTTON_EVENT[devATC_KEYPAD]
    	  TO[vdvTPd,BUTTON.INPUT.CHANNEL]
    		IF(BUTTON.INPUT.CHANNEL = atcSTAR)
    			cKEYPAD_ENTRY = '*'
    		ELSE IF(BUTTON.INPUT.CHANNEL = atcPOUND)
    			cKEYPAD_ENTRY = '#'
    		ELSE
    		IF(iPHONE_OFF_HOOK = 1)
    			SEND_STRING dvXAP,"atcDEV_XAP400,atcDEV_ID,' DIAL 1 ',cKEYPAD_ENTRY,$0D"
    			cPHONE_NUMBER = "cPHONE_NUMBER,cKEYPAD_ENTRY"
    			SEND_COMMAND vdvTPa,"'TEXT11-',cPHONE_NUMBER"
    		ELSE
    BUTTON_EVENT[vdvTPd,atcFLASH]	// Flash
    	  SEND_STRING dvXAP,"atcDEV_XAP400,atcDEV_ID,' HOOK 1',$0D"
    BUTTON_EVENT[vdvTPd,atcCALL_ANSWER] // Call / Answer
    		IF(LENGTH_STRING(cPHONE_NUMBER) > 0)
    			SEND_STRING dvXAP,"atcDEV_XAP400,atcDEV_ID,' DIAL 1 ',cPHONE_NUMBER,$0D"
    		ELSE
    			SEND_STRING dvXAP,"atcDEV_XAP400,atcDEV_ID,' TE 1 1',$0D"
    BUTTON_EVENT[vdvTPd,atcANSWER] // Answer
    		SEND_COMMAND vdvTPa,'@PPF-Incoming Call'
    		IF(!iSYSTEM_POWER)
    		  CALL 'SYSTEM ON'		(* REV0 *)
    		  DO_PUSH(vdvTPa,14)	(* SELECT ATC MODE *)
    BUTTON_EVENT[vdvTPd,atcCLEAR]	// Clear
    		cPHONE_NUMBER = ''
    		cKEYPAD_ENTRY = ''
    BUTTON_EVENT[vdvTPd,atcBACKSPACE]	// Backspace
    			SET_LENGTH_STRING(cPHONE_NUMBER,(LENGTH_STRING(cPHONE_NUMBER) - 1))
    BUTTON_EVENT[vdvTPd,atcHANG_UP]	// Hang Up
    		cPHONE_NUMBER = ''
    		cKEYPAD_ENTRY = ''
    		SEND_STRING dvXAP,"atcDEV_XAP400,atcDEV_ID,' TE 1 0',$0D"
  • avi_daveavi_dave Posts: 62
    much appreciate it boss, much appreciated :D
  • alanhalanh Posts: 30
    Although the above code is for XAP units and for G4 panels, is there any reason for the phone number not to appear in the variable text box on a G5 panel, i have replaced the Text11 command with ^TXT-11,0 and when i put in a manual test string for a button event like SEND_COMMAND vdvTPa,"'^TXT-11,0, 123456'" it works and shows 123456 in the variable text box 11, but using the above code the CHAR cPHONE_NUMBER does not appear in the variable text box 11 but the code works and the unit dials and connects etc, what any i missing here any help greatly appreciated, i know it will be something simple, the code and variable text box both work on a TP4 touchscreens as i just copied and pasted previous working examples and changed the TEXT11- where ever it was used.
