MVP8400 with dynamic image
Denis
Hi
In my demo MVP8400, I inserted a dynamic image to simulate a doorcam, this image is on our web site and it's linked to panel trough dynamic image via url
This function was worked for 1 1/2 years without problems. Since few weeks, I don't know why, I can't get this image
I revised router set-up and all seem ok
Some body can help me?
if you double click on your dynamic image, it should popup the current image
Do an nslookup on your dynamic image URL. Instead of using the domain name in the the dynamic image properties, enter the IP address instead. That should fix your problem. If this confirms the problem, then edit the DNS server properties in the MVP Wireless setup pages. I use 68.12.16.25 (Cox DNS) and 4.2.2.4 (Verizon DNS). Good Luck!!
