Clearone Level 2 TP Bargraph
Since the clearone calculates all its ramping and gaining on a "DB" figure how should I throw this value to a TP bargraph I know there is some setting and or formula involved
level_event [dvClear1,1]
ClearVolResp = Level.sourcedev
send_level dvTP, 1, level.value
I get a error on compile, convert type dev to integer
The compile error is probably because of
The RHS is a device, presumably the LHS is not.
Here is my code to adjust from the ClearOne AP800's range of -20..+20 to a range of 0..255
sinteger siVolumeMinimum = -20 (* or -66 depending on model *) sinteger siVolumeMaximum = 20 sMyValue = itoa(type_cast(SignedAdjustFrom255(nArgVolume,siVolumeMinimum,siVolumeMaximum))) (******************************************************************************) define_function sinteger SignedAdjustFrom255( (* Result in range below *) integer nArgValue , (* Input - Value in range 0 - 255 *) sinteger siArgMinimum , (* Input - Minimum input value *) sinteger siArgMaximum ) (* Input - Maximum input value *) (******************************************************************************) { stack_var sinteger siMyValue (* Have to do this to avoid a compiler warning *) siMyValue = type_cast(nArgValue) return ((siMyValue * (siArgMaximum - siArgMinimum)) / 255) + siArgMinimum; } (* SignedAdjustFrom255 *)However that's the wrong direction. I haven't yet had to code SignedAdjustTo255 but here is the unsigned version:
(******************************************************************************) define_function integer AdjustTo255 ( (* Output - Result in range 0 - 255 *) integer nArgValue , (* Input - Value to convert *) integer nArgMinimum , (* Input - Minimum input value *) integer nArgMaximum ) (* Input - Maximum input value *) (******************************************************************************) { return (((nArgValue - nArgMinimum) * 255) / (nArgMaximum - nArgMinimum)); } (* AdjustTo255 *)
