someone knows how to work on ip!!
hello !!
i need some code examples how to work with ip on the new controlers like NI200 AND 700 AND MYBE 4000.
i intent to buy a NI2000 controler from E-bay and do a web interface gui and control my living room from my laptop.
so :
1. i need how to do a web interface tochpanel ?
2. i need to know how to send string to ip device on my living room(vsx7000,kramer vp84eth).
i have found a code that saied haw to send string to ip client but it seem to drive the system crazy...
i hope pepole here have some ideas how to help get going before i buy one to my self and get crazy!!
I dont have anuff money for tps ---so that why i need for the meen-time to build a code on web interafce ,or if excist EXE-application like i saw on a client that called -XPANEL but it isn't amx .
thanks for your help anyway!!
so :
Follow these excellent instructions from Joe Hebert
http://amxforums.com/showthread.php?t=335&highlight=g3+web+control
For the other question, can you show us what the other code you have thats driving the system crazy is? It could be something simple thats messing you up, but its much easier to glance at existing nonfunctional code than create something from scratch
J
so if i have tpd4 gui in order to turn to tp3 i cant ,so i need to build a tpd3 and send to web!!
right
now what about an easy way to send string to an ip cient!!?
thanks
i hope i understood currectlly!!!!
i will try...
i am still lookind for sample code for m kind of configuration like:
web based tps and a ip controler of amx....
******** has on every controler that has an ip card an xpanel that can send commands and used as an ordinarry tps....
i saw on several clients!!
