Address book Module/Code
Hi all,
I was wondering if any one would have or know of an "Address book" module/code that I could get my hands on.
I'm after function like add, remove, edit, sort and find.
Regards
Craig
Regards
Craig
Hi.... You should say address book for what?? which device, model, manufacturer..
Go to InConcert and .. search, if you don't have an account, sign up for one.
This should give you an idea how to do it, just provided the helper functions.
DEFINE_CONSTANT MAX_STRUCT_ITEM_LENGTH = 50; MAX_ADDRESSBOOK_ENTRIES = 100; DEFINE_TYPE STRUCTURE _AddressBookEntry { CHAR cFirstName[MAX_STRUCT_ITEM_LENGTH]; CHAR cLastName[MAX_STRUCT_ITEM_LENGTH]; CHAR cAddress1[MAX_STRUCT_ITEM_LENGTH]; CHAR cAddress2[MAX_STRUCT_ITEM_LENGTH]; CHAR cCity[MAX_STRUCT_ITEM_LENGTH]; CHAR cState[MAX_STRUCT_ITEM_LENGTH]; CHAR cZip[MAX_STRUCT_ITEM_LENGTH]; CHAR cPhone[MAX_STRUCT_ITEM_LENGTH]; CHAR cFax[MAX_STRUCT_ITEM_LENGTH]; CHAR cEmail[MAX_STRUCT_ITEM_LENGTH]; } DEFINE_VARIABLE non_volatile _AddressBookEntry uMyAddressbook[MAX_ADDRESSBOOK_ENTRIES]; VOLATILE _AddressBookEntry uUserEntryItem; DEFINE_FUNCTION INTEGER CompareAddressBookItems (_AddressBookEntry uItem1, _AddressBookEntry uItem2) { IF ( (uItem1.cAddress1 == uItem2.cAddress1) && (uItem1.cAddress2 == uItem2.cAddress2) && (uItem1.cCity == uItem2.cCity) && (uItem1.cEmail == uItem2.cEmail) && (uItem1.cFax == uItem2.cFax) && (uItem1.cFirstName == uItem2.cFirstName) && (uItem1.cLastName == uItem2.cLastName) && (uItem1.cPhone == uItem2.cPhone) && (uItem1.cState == uItem2.cState) && (uItem1.cZip == uItem2.cZip) ) RETURN TRUE; ELSE RETURN FALSE; } DEFINE_FUNCTION INTEGER FindAddressBookEntry (_AddressBookEntry uItem) { STACK_VAR INTEGER nLoop; FOR (nLoop = 1; nLoop <= MAX_LENGTH_ARRAY(uMyAddressbook); nLoop++) IF (CompareAddressBookItems(uItem, uMyAddressbook[nLoop]) == TRUE) RETURN nLoop; RETURN 0; } DEFINE_FUNCTION INTEGER AddAddressBookEntry (_AddressBookEntry uItem) { STACK_VAR INTEGER nLoop, nLocation; STACK_VAR _AddressBookEntry uAddressbookNull; // SEE IF ALREADY IN ADDRESSBOOK nLocation = FindAddressBookEntry(uItem); IF (nLocation == 0) { // GET NEXT AVAILABLE SPOT nLocation = FindAddressBookEntry(uAddressbookNull); IF (nLocation > 0) { uMyAddressbook[nLocation] = uItem; SortAddressbook(uMyAddressbook); RETURN nLocation; } } RETURN 0; } DEFINE_FUNCTION INTEGER DeleteAddressBookEntry (_AddressBookEntry uItem) { STACK_VAR INTEGER nLoop, nLocation; STACK_VAR _AddressBookEntry uAddressbookNull; // SEE IF ALREADY IN ADDRESSBOOK nLocation = FindAddressBookEntry(uItem); IF (nLocation > 0) { uMyAddressbook[nLocation] = uAddressbookNull; SortAddressbook(uMyAddressbook); RETURN nLocation; } RETURN 0; } DEFINE_FUNCTION INTEGER UpdateAddressBookEntry (_AddressBookEntry uOldItem,_AddressBookEntry uUpdateItem) { STACK_VAR INTEGER nLoop, nLocation; // SEE IF ALREADY IN ADDRESSBOOK nLocation = FindAddressBookEntry(uOldItem); IF (nLocation > 0) { uMyAddressbook[nLocation] = uUpdateItem; SortAddressbook(uMyAddressbook); RETURN nLocation; } RETURN 0; } DEFINE_FUNCTION SortAddressbook(_AddressBookEntry uAddressbook[]) { STACK_VAR INTEGER nLoopA, nLoopB; STACK_VAR _AddressBookEntry uHold; STACK_VAR _AddressBookEntry uAddressbookNull; FOR (nLoopA = 1; nLoopA <= MAX_LENGTH_ARRAY(uAddressbook); nLoopA++) { FOR (nLoopB = nLoopA + 1; nLoopB <= MAX_LENGTH_ARRAY(uAddressbook); nLoopB++) { IF (CompareAddressBookItems(uAddressbook[nLoopB], uAddressbookNull) == FALSE) { IF (uAddressbook[nLoopA].cLastName >= uAddressbook[nLoopB].cLastName && uAddressbook[nLoopA].cFirstName > uAddressbook[nLoopB].cFirstName) { uHold = uAddressbook[nLoopB]; uAddressbook[nLoopB] = uAddressbook[nLoopA]; uAddressbook[nLoopA] = uHold; } } } } } DEFINE_START uUserEntryItem.cFirstName = 'Judy'; uUserEntryItem.cLastName = 'Jetson'; AddAddressBookEntry (uUserEntryItem); uUserEntryItem.cFirstName = 'Astro'; uUserEntryItem.cLastName = 'Jetson'; AddAddressBookEntry (uUserEntryItem); uUserEntryItem.cFirstName = 'George'; uUserEntryItem.cLastName = 'Jetson'; AddAddressBookEntry (uUserEntryItem); uUserEntryItem.cFirstName = 'Jane'; uUserEntryItem.cLastName = 'Jetson'; AddAddressBookEntry (uUserEntryItem); uUserEntryItem.cFirstName = 'Rosy'; uUserEntryItem.cLastName = 'The Maid'; AddAddressBookEntry (uUserEntryItem); uUserEntryItem.cFirstName = 'Elroy'; uUserEntryItem.cLastName = 'Jetson'; AddAddressBookEntry (uUserEntryItem);
