Mvp 7500
ryanww
in AMX Hardware
I have a MVP 7500 that keeps freezing about half way through any transfer. I have tried multiple times over wireless as well as USB, and it still does it. I even tried re-loading the firmware, but half way through the 2nd file it froze. I had a page on it, and then when I tried re-loading a page it wiped it out and now it is blank. It has the latest firmware on it. Does anyone have any recommendations?
Thanks, Ryan
Thanks, Ryan
I find that MacAfee holds up my transfers and tries to scan the files as they are transfered.
Ryan
Ryan
Ryan
Hi... I had a similar problem like this when the power went down during the firmware installation on NI, unfortunatly you cannot reflash your device at your place, you have to send it back to your nearest AMX tech support and they will manage this for you, this is if it is true that the firmware is faulty, If you can transfere the firmware again, please make sure it is version 2.72.2, if it is not, get it from Here
if this is the version you are currently transfering, you should give AMX support a call, and they will tell you what to do and try to give them info as much as you can, one more thing.... try to remember when exactly this problem appeared, and what was happening or you were doing at this time.
