poppus
Is there any equivalent for TPDesign "hide popups on page" command in nexlinx code?
And why I have to give for the hide group command a specific page name and not the group name?
thanks
Ady.
thanks
Ady.
Close all popups on a page. If page name is empty, the command has no
effect. (Same as a 'Clear Page' command in TPDesign 4)
Clear all popup pages from a specified popup group.
Syntax:
SEND_COMMAND <DEV>,"'@CPG-<popup group name>'"
Variable:
popup group name = 1 - 50 ASCII characters.
Name of the popup group.
Example:
SEND_COMMAND Panel,"'@CPG-Group1'"
Clears all popup pages from the popup group 'Group1'.
A good resource for referencing these commands can be found in Software History. It can be launched separately, or you can find it in Netlinx Studio under Tools->Software History. Look up the model number of the touchpanel you're using, then you'll see the command sets that are available for it. It can be an invaluable resource.
--John
What will I do without this forum
I looke at the modero 8400 manual and missed those commands.
and good to know about the software history tool
thanks again and have a greate weekend!
Ady
'@PPX'
will close all currently active popups.
I use this one quite often because I commonly have 2-3 popups open at once.
You guys always forget about PI, specially the online public version, it is awesome
here
