poppus
adysadys Posts: 395
Is there any equivalent for TPDesign "hide popups on page" command in nexlinx code?
And why I have to give for the hide group command a specific page name and not the group name?
thanks
Ady.
  • mpullinmpullin Posts: 949
    "'@PPA-<page_name>'"
    Close all popups on a page. If page name is empty, the command has no
    effect. (Same as a 'Clear Page' command in TPDesign 4)
  • funkyskierfunkyskier Posts: 48
    "'@CPG-<popup group name>'"
    Clear all popup pages from a specified popup group.
    Syntax:
    SEND_COMMAND <DEV>,"'@CPG-&lt;popup group name>'"
    Variable:
    popup group name = 1 - 50 ASCII characters.
    Name of the popup group.
    Example:
    SEND_COMMAND Panel,"'@CPG-Group1'"
    Clears all popup pages from the popup group 'Group1'.
  • John GonzalesJohn Gonzales Posts: 609
    Software History
    A good resource for referencing these commands can be found in Software History. It can be launched separately, or you can find it in Netlinx Studio under Tools->Software History. Look up the model number of the touchpanel you're using, then you'll see the command sets that are available for it. It can be an invaluable resource.
    --John
  • adysadys Posts: 395
    Thanks guys!
    What will I do without this forum :)
    I looke at the modero 8400 manual and missed those commands.
    and good to know about the software history tool
    thanks again and have a greate weekend!
    Ady
    there is also the nuclear option
    '@PPX'
    will close all currently active popups.
    I use this one quite often because I commonly have 2-3 popups open at once.
  • SensivaSensiva Posts: 211
    Don't Forget this one also
    You guys always forget about PI, specially the online public version, it is awesome
    here
