NI Security & Programming Emulator
 Sensiva
Sensiva
                    Hi all,
I had a problem getting the "AMX Programming Practical Emulator" working
I have NI-3000 and made the instructed modifications and the connection green led in the emulator is blinking which means it is connected to the master, but the emulator is not listed in the online tree in Netlinx studio, and doesn't receive any response from the touchpanel emulator window...
The problem is simply the NI Security... once disabling it.. everything is fine... the emulator should appear in the online tree in the Netlinx Studio.. and your commands are received
Hope this helps for all ppl going throu ACE Programmer
Bob
It's not necessary that all people are smart as you
Cheers
It's not a perfect tool but a very helpful one. The only glitch that I have experienced is there is no mention in the white paper that the Camera on system 100 has to be addressed differently as well as the other devices when using the emulator. It has to be 8100:1:0 to work but you can watch the notification messages when you connect the emulator and select the cameras to find that out. Just thought that I'd mention that for those of you who couldn't find the info in the note.
Unfortunately it's not available for download, add for this after getting more into this exam, i found that this emulator, is not a worthy thing to have. Because of this i had to test my program on a real Touch panel, cause i don't know if my code is not working , or the emulator is the one which is not working
After finishing up my exam , i'll post here in this topic a list of its bugs, that driven me MAD.
So far the only thing I am yet to get to work is having it reply text and information I send to the variable text address on the emulator program. I am using: SEND_COMMAND dvTP,"'^TXT-53,0,'<text>" and it either displays nothing or an error. Does it need to be the old G3 style text with is the !T or whatever?
Yes you have to use !T - at least that's what my code does.
It doesn't work with the ^txt command, i though like you, it will be with the ^txt command, but anyway they didn't mention which TP in project, so they won't take this into count... Don't worry .
Thanx NMarkRoberts for this notice.
But... ryanww, in the DVD player , did the Skipping buttons respond to the TO keywords?
Ryan
In the remote camera part, should i assume that my master is included in the other masters URL List?
In the CD Changer part, the No. Of Tracks text field, should show the total no of tracks of the current disc, or should show the the No. of the currently playing track?
And for the CD Changer, I would assume just the total number of tracks since theres no way to verify that it has gone from one to the next. I think they just want to make sure something ends up showing.
Ryan
Try to use 'TEXT<variable text address 1-255>-<new text to be put in button>' and you will see a message saying "You must use either the @TXT or the !T syntax to set your var text"
And the emulator is not fine, it has list of at least 5 bugs, and i am going to list them once i get my certificate, by the way it's a Visual Basic program with PCLinkplus OCX, uses almost 8 MB of memory, i think one of the AMX'ers has volunteered to design this program and has not been enhanced since 2002.
I hope someone will rewrite this program and its documentation, to help the coming AMX Programmer students. Because as a student, the first thing i assume - once things are going wrong - that my code is not fine, and start to roll over it again and again.....
I am not a thankless person, the credits of achieving my programmer certificate (i hope i pass it) go to the authors of this emulator, It was very helpful in raising our knowledge about Netlinx code.
It is a god concept, just poor execution..
With TPD4 can you emulate a tp just using a file live? I don't know much about that, just something I was wondering.
Ryan
I crawled the AMX-PI, searching for text assignment commands, then I tried these commands one by one using telnet Send_command TP,"Blah Blah" while running the TP emulator - Note : you TP should be defined in your program, or you have to send it to 8001:1:0 - , till i sent the 'TEXT<variable text address 1-255>-<new text to be put in button>' command, i saw the message in the boxes of CDChanger tracks info.
About your question... I can't understand what do you mean...
The programming practical emulator isn't really emulating a G4 panel, it's just providing buttons that send push/release messages when pressed. G4 Panel Preview is the only way to emulate a G4 panel, but it only handles the graphics side, not control. G3 Web Control is the only way to run an actual TP on a PC.
I agree that the emulator is a little crotchety, but I think it's good preparation for working with real-world devices, which also have bugs.
Jeremy
Ryan
In speaking of touchpanel emulation, I wanted to practice, but there were no touch panels in my place, and it is too costly for me to buy a new panel, so i started [thread=2322]this thread[/thread] , to ask about emulating a touch panel using an application like the panel previewer, and they gave me a worthy info up there , i suggest to read it.... and thanks to them.
But for this, I would imagine it would work just fine to get the project done.
Ryan
The Web Touch panels is not buggy at all..... fully functioning, may be the java installed in your system is corrupted.
The nice thing about that emulator is that like if you don't send it the correct online commands, it does nothing. Hence telling you that you did it wrong.
