ni 3000 don't go up
in AMX Hardware
I have ni 3000, when I connect it to the power all the leds are going as they should in all controllers, but after that the yello led of input stays on forever, and I cannot connect to it using serial cabel...
is there is somthing to do before I go to replace it?
thanks
Ady.
update:
now the input and the ouput leds are on forever...
thanks
Ady.
update:
no.
I am was not familiar with this trick...
tired now, same thing, input and output leds are on.
Somtimes both, somtimes only input stays on after reboot
just found this
http://www.amxforums.com/showthread.php?t=2343&highlight=input+led
I hope this is now my case
If so, you can set ip and get it to a static address to ensure that it is not looking for a DHCP server. Then reboot and see what it does.
Sounds like your code is stuck in an infinite loop. Are you sure you flipped the dip switch and rebooted, that should bypass your code completely and get you out of the loop.
In this case, the unit must be sent to AMX for repair.
This is very likely. I had two units fail like that in a row, and got tech support to admit they had a bad run of compact flash cards. You may have had the bad luck of getting one they didn't catch.
Its new from the box, so my code was never there...
Thanks all, I will replace it soon and let you know what was the problem.
It is almost surely a network related issue and if you persist with the serial cable connection you will eventually establish coms with the unit.
Even though the serial connection keeps failing, just keep trying until you get it. Once connected, set a new IP address and you should be fine.
Hope it helps.
