pdp-614MX
I have tried everything to control this plasma even called tech support for it and they said hey there is no real documentation on it. I dug up a pdf checksum file on it but it doesnt seem to want to do what I need. I throw codes out at its default rate which is 9600 I get nothing I tried 38400 I get sometimes 0s or a ACK but no change on the display has anybody encounter this display maybe you can help me out.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/292445008PDP614MX_ECM.pdf
You may also need to set the ID & Baud Rate in the menu on the actual panel itself. A lot of Pioneer displays default at 4800 (although this manual says 9600).
I tried all that, I even asked the dealer if he could point me to the menu where I can set the baud rate he said there is no service or ccommunications menu.
checksum calcualted and everything, did I miss something?
nON = "$9F,$80,$60,$4E,$00,$CD"
nOFF = "$9F,$80,$60,$4F,$00,$CE"
nVID = "$DF,$80,$60,$47,$01,$01,$08"
nRGB = "$DF,$80,$60,$47,$01,$07,$0E"
nCOMP = "$DF,$80,$60,$47,$01,$05,$0C"
even at 4800 nothing came outta this baby, im stuck :P.
What ID do you have set at the mo?
Baud is certainly 9600
Power On
SEND_STRING dvPlasma,"$9F,$80,$60,$4E,$00,$CD"
Power Off
Your strings look ok, have you tried sending them from a terminal?
Have you got some code to look at?
Just on the off chance set Parity to Odd rather than none
DATA_EVENT [dvPlasma]
ONLINE:
SEND_COMMAND dvPlasma, 'SET BAUD 9600,O,8,1 485 DISABLE'
