Data Event
                    is there any whey to know the system number of the Command sender to data event?
I mean I want to know who send the command to here
DATA_EVENT[vdvStatusCmd]
COMMAND:
I know I have the Data.Device.System but that gives me the vdvStatusCmd system..
thanks
Ady.
COMMAND:
thanks
Ady.
I checked it now, and its the same as Data.Device.System
I am sending message from system 3 to system 5, and I get value 5 in both ..
When taking it in the sender side from getlast[tpList] it 3 as it should
I can send it in the string command, but I preffer more elegant solution
I tried every scenario I could think of for Button.SourceDev and Data.SourceDev and found that:
SourceDev.Number always returns 0
SourceDev.Port always returns 1
SourceDev.System always returns the system number that the code is running in.
Here is a link to a thread from last year that addressed the subject although it was kind of left up in the air with no confirmed resolution.
http://www.amxforums.com/showthread.php?t=1333
So the only solution is to take the System number before I send the string and put it in inside the string commnad
so I did
if anyone knows about other solution I will love to know
Ady
