WAIT Behavior Question
Greetings,
I am trying to understand the behavior of statements within WAITs that contain variables.
For example:
nX=0
WAIT 10 nVALUE=nX
nX=1
If nX changes values after the start of the wait, but before the execution of the delayed operation, will nVALUE equal 0 or 1? And does this rule apply across all variable types, waits, etc?
Thanks.
    Greetings,
    For example:
    nX=0
    WAIT 10 nVALUE=nX
    nX=1
    Thanks.
    It depends upon where this hunk of code lived in the program.
    If it were in the Define_Program section then:
    DEFINE_PROGRAM
    nX=0
    Wait 10
       {nVALUE=nX} // end wait 10
    nX=1
    then nX is constantly being changed from 0 to 1 to 0 to 1 over and over... It would depend upon which clock cycle the wait hit on.
    However, if this hunk were part of a command like
    if(do_something_flag)
      nX=0
      Wait 10
      nX=1
      do_something_flag=0 // clear out the flag
      } // end if do something flag
    OR
    BUTTON_EVENT[dvTP_1,1]
      nX=0
      Wait 10
      nX=1
      }// END PUSH:
    }// END BUTTON_EVENT
    Then nVALUE=nX Will Equal 1
  • dchristodchristo Posts: 177
    DEFINE_PROGRAM
    nX=0
    Wait 10
    nX=1
    Since a Wait will never expire in the middle of mainline, you can expect that nValue will always be 1 in this example, even if this code is in DEFINE_PROGRAM.
    --D
    dchristo wrote:
    Since a Wait will never expire in the middle of mainline?
    Sure it can. This program will toggle the variable nFlash once per second:
    INTEGER nFlash
    DEFINE_PROGRAM
    WAIT 10 nFlash = !nFlash
    Greetings,
    nX=0
    WAIT 10 nVALUE=nX
    nX=1
    Thanks.
    I should have said that the above code would be within an event that would run once.
    INTEGER nFlash
    DEFINE_PROGRAM
    Yes, you are correct that this will toggle nFlash. However, in the code presented:
    DEFINE_PROGRAM
    nX=0
    Wait 10
    nX=1
    nValue will never be equal to 0 in this context (and has no chance at all to become 0). This is because when the Wait is encountered, it is placed into a queue, and this queue is checked for expired waits after Mainline has executed, therefore the line "nValue=nX" will always resolve to 1, because mainline will have completed before the waits are evaluated.
    --D
    My bad. I misinterpreted what you wrote. Now I see where you're coming from and it makes perfect sense.
    The NetLinx code that we write looks like it's multithreaded, allowing stuff to happen asynchronously, but it isn't. Everything takes turns in a single thread.
    This almost always doesn't matter, but it's important to understand for some situations, like this one. It means that you can regard all chunks of code as atomic - that is, guaranteed to complete without any other chunk of code interfering with the variables that your code is using.
    Whenever this situation arises in my code I always write a big fat comment to clarify it as it is easy to miss.
    By "chunk of code" I mean the code you find in define_start, define_program, and various define_events. A function call is not a separate chunk. When you code a wait you are creating another separate chunk of code which is internally atomic but is independent of the code either side of it.
    The runtime system presumably IS multithreaded to allow everything except the code you write to do stuff in the background. This might imply that (eg) the state of a buffer could change halfway through the code that is using it. Can anyone clarify that?
    I believe the short answer is no. The message queue(s) keep the peace.
    While the OS runs in its own thread and can service the outside world at the same time our program is looping around, any messages that the OS generates have to be put into the queue first before our program can see/handle them. Our program handles one message (event) at a time (first come first serve.) So even though data might be waiting at the door it doesn?t affect our program because we have a built in buffer (the queue.)
    This is only speculation but I think CREATE_BUFFER in DEFINE_START registers an event handler before any of our defined event handlers. But whatever the case I don?t believe that the buffer contents will be altered by any outside force other than a message from the queue.
    End of long answer...
