$SC command?
Hello All
I have a client with an old VPT-CP panel that would now like a warm/cool page added. I have made these as pop-up pages. I want the page to flip to the source page after the pop up is done. Normally I'd just code this but since this is a 1-way RF panel I can't do that. I was talking to tech support and they suggested that I use the 'string output' section of TP3 to do what I want. He suggested a $SC command and then have the panel flip to the source and then activate the pop up page. I wrote the code down as he told me but can't seem to get it to work. Since I have never done this myself I am somewhat at a loss . Any help would be much appreciated.
Here's what I had written down.
"$SC 1,"'@PPO-warm'""
    Is @PPO a valid command? Try PPON instead and see if that works.
    Opp's the 'N' is in my code I just missed posting it here.
    What firmware version has the VPT? On panels with serial numbers starting 962 and 963, the onboard commands are only supported in firmware version 5.03.
    There is no '@' in the PPON command. the '@' version is @PPN, if you use PPON, it's just PPON.
