RFID! Anterus
Is anyone else excited about this product? I CAN'T WAIT (to get my hopes dashed due to unrealistic expectations)! I imagine being able to switch an MVP-8400 to the current room when the touchpanel enters the room. Being able to display the last received location of your car keys/cell phone/remote/whatever on a house overview. Having music follow you through the house. And MORE!
I can't wait to see the actual production specs so that I can reign in my expectations.
Que?
(The message you have entered is too short. Please lengthen your message to at least 10 characters.)
Here is the press release:
http://www.amx.com/newsroom/pressrelease-file.asp?release=2007.6.19.b
Agreed though, I just want to download the manual... I looked at some other RFID stuff and it seems the trick is you need a lot of well placed receivers for it to work - that can be a little tough in a residential install.
Curt
It's designed for ages 2 and up.
Blue or pink color option.
Waterproof.
Nice!
Just thinking out loud . . .
Back in the Navy days the fire control techs could cook a seagull at 100 meters all be it with a powerful fire control tracking radar with all the RF power concentrated to a pin point at over a Mega Watt of power.
Now lately I've been wondering as I sit amidst 3 MVPs, a laptop and 2 access points on different subnets. That's just the stuff with in 10' of my seat. Low level of RF x 10 hours per day x 7 days per week x 365 days per years. I thought I was fried but that used to mean from stuff I did in the 70's & 80's not from my present sedentary life.
Not so appropriate at handover though!
http://www.lessemf.com/personal.html
Does make you wonder though....
During the presentation at the pre-InfoComm AMX meeting, Rashid walked to a lectern, the RFID receiver recognized that his tag was approaching, and started his presentation.
We are envisioning more commercial applications:
Monitoring the location of a/v and video conference carts in corporate or education environments, etc.
As far as exploring residential applications, the ball is in motion to start to investigate the application you outlined above.
The issue that is going to be addressed is whether the RF output of the tag will interfere with the Wi-Fi or Zigbee range of the current wireless devices, or vice versa.
RS-485 (this has been from a single source only, and I'm a little disturbed by this)
Active RFID - 5 Year battery, why it isn't a passive induction based one I don't know...
it appears that one of the 'board' made their billions doing RFID toll paying, I assume it is along the lines of this (a broad assumption, but I'm sure not far from the truth).
As for putting it over RS485.... may I be the first to say.. WTF. That really confuses me. I've used RFID solutions before, ground loops in the driveway, Doorway ones to track users movement through houses, and such like. I am just astounded they haven't gone done the ethernet TCP/IP route with this product.
It makes me cry
As for active RFID, I would guess that this has something to do with the range of transmission. I am completely speculating here as I have not had the chance to play with RFID yet, but it seems to me that a passive tag would not have the range of an active tag.
I can't wait to get a couple to play with tho
++2 ushielded Wires instead of 8 shielded
++no switches or active parts needed, when more than one device is connected
-- only one message can be send to a device at a time
-- smaller amounts of data can be transferred, although I think that there won't be huge amounts of data
-- one of the scarce RS-485 ports of the netlinx master is used
other pros/cons?
Pro:
RS485 can be easily daisy-chained (as opposed to the IP's star topology). This _can_ result in shorter cable runs. If you've got many end-points in the system, you still only need one cable running back to the master. Less physical space could be advantageous.
Con:
A break in a daisy chain will take out more than one end-point.
Hello,
We ordered the RFID anterus and we are now busy integrating it into a system.
In the installation guide they say that you need to instal it through the webutility through the processor but he doesn't shows up. I can see him but it is an unrecognized device ? So he doesn't shows up in the webcontrol section / manage devices.
Into the manual they talk about a TP4 panel demo, but I cannot find it ??
Anybody already worked with it ?
Thank You
I intend to use it for a residential project where the house will respond differently depending on who arrives. A driveway sensor trigger alone will trigger different events than one combined with a read from an Antrus tag.
