TP Connections
After my recent NI4000 (2) crashes I modified my code to work on a NI2100 so I can continue the struggle, removed the 4000 from the network, changed IP of the 2100 to that of the 4000, set it to system 1 (same as the 4000) and expected my TPs to connect. Much to my dismay they didn't.
In diagnostics I get:
which I've never seen before.
and on the TPs connection page I get "Authentication Failed" are they locked onto the mac of the previous master? Everythings been rebooted, refreshed and repeated several times.
What authentication? These devices are defined in the code, the TPs are set to the URL w/ the proper IP of the 2100, DNS entries are set. I have my normal user and priveleges set under the master security tab.
This is my first usage of this particular master and I don't recall any issues like this on other x100 models.
Any help would be appreciated before I go into a full mental melt down!
Line 1635 :: ICSPTCPRx31: Error in Authentication Sys=1 Dev=10004 Error -2 - 08:31:43 Line 1636 :: ICSPTCPRx31: Error in Authentication Sys=1 Dev=10003 Error -2 - 08:31:44 Line 1637 :: ICSPTCPRx31: Error in Authentication Sys=1 Dev=10002 Error -2 - 08:31:45 Line 1638 :: ICSPTCPRx31: Error in Authentication Sys=1 Dev=10001 Error -2 - 08:31:46
Maybe from the Webinterface of the NI-2k1, the ICSP Security is enabled. So the panels can find the master by correct URL, but have an incorrect or unset username and password in system settings to establish communication.
Marc Scheibein wrote: Yep, that did it. In the master's web browser under "Security", "Systems Level" tab the enable check box at the top was checked. All the other check boxes were checked including "ICSP Connectivity" the sub check box for "Encrypt ICSP Connection" was not. Un check the "ICSP Connectivity" check box and now all is well. Everything else was left checked as normal.
If I were to leave this enabled where in the TPs set up would I configure this?
Or may be your old master was configured to have an Username and password, which means that the panel is the same too, if you are sure that the new 2k one doesn't have a password, then follow alexanbo steps and clear them on the panel.
